I have a 2002 MCS and was wondering what is the best solution for hooking up an ipod to the 2002 stock radio. I have been looking into two options. #1 the Dice intergration kit $149.00 or #2 the Harman Kardon Drive and Play ($19.99 cant beat the price).
My main question is about the HK Drive and Play (yes I have searched) can you hook up a aux jack to the stock 2002 radio i want the ipod to go through the stereo not as an fm transmiter. Is this possible on the 2002 radio?
Also there is no way the ipod text would show on the stock radio with the Dice Kit, is that correct?
I'm under the impression that the 2002 head units aren't capable of supporting an aux in...
https://www.northamericanmotoring.co...light=aux+2002
Patience, grasshoppah.
Depends what 2002 head unit you have. Some of the earlier 2002 HU's don't support the AUX input. (or CD changer)
However, if you have a model that does support it, then the answer is "yes".
Although I did mine with junk parts, I did a write up which may help you become more familiar with the AUX side of things.
http://www.geekshocker.com/Claire/audio/compAux.php
Also, from this page: http://www.diceelectronics.com/Merch...e=i-BMW-T-Mini
it would seem that, no, you will not have text on the HU.
You'll need to find someone with a newer model who has gone aftermarket with their stereo. This was a big problem early on, but now there are enough cars out there with aftermarket stereos that you should be able to find one here in the marketplace if you place a want ad.
Ok thanks for the answers guys.
But I still have some questions. If my car is wired for the cd changer am I able to hook an aux up to that?
Sorry this is all new to me. Does anyone know when the radio changed in 02 was it Aug 02 does anyone know an exact date because my car was made in Aug 02
Quote:
Technically yes, but AFAIK only at a cost (~$350) far exceeding the OEM aux-in.Originally Posted by x2boxers
Quote:
Not sure what the change date is, but IMO your best course of action is to get the OEM aux-in. Plug it in to your stereo. If it works, voila. If not, you'll need it anyway when you get a newer head unit.Originally Posted by x2boxers
...Sorry this is all new to me. Does anyone know when the radio changed in 02 was it Aug 02 does anyone know an exact date because my car was made in Aug 02
Quote:
The DICE kit will work in your case: Originally Posted by x2boxers
35 people viewed this and Nobody has an answer???
DICE - SILVERLINE iPod Integration Kit for MINI Cooper (Radio Interface)
http://www.europeanautosource.com/pr...oducts_id=1639
This is the newest kit to be released from DICE.
I have 7/2002 Build Date MCS and the Harman Kardon Drive and Play 1. Is it posible to hard wire it to the cd changer wires. If not any idea's how to hard wire it to the stock system?
Quote:
Sure, this is the kit you need: Originally Posted by x2boxers
DICE - SILVERLINE iPod Integration Kit for MINI Cooper (Trunk Interface)
http://www.europeanautosource.com/pr...oducts_id=1637
Thanks Tom I understand that your kit will work, but I cant swing the $ 150.00 right now I was just wondering if it was an option to hard wire the HK Drive and Play directly to the cd changer boot wires. Tom I dont expect you to answer this since you are trying to sell the kit. But just asking if the head unit will recognize the Drive and Play and let it be accessed from the mode button as a cd changer?
Or he could go with the Blitzsafe M-Link for less than half the cost...Originally Posted by tom @ eas
Sure, this is the kit you need: DICE - SILVERLINE iPod Integration Kit for MINI Cooper (Trunk Interface)
You won't be able to use the MFSW to control your iPod. You just use it like normal. Sound quality is perfect and obviously it charges your iPod. For around $50 (even cheaper now than when I got it), at EnfigCarStero, it's the best solution IMO...
