Navigation & Audio Need Help with My R56 Car Audio
Old Jan 1, 2008 | 08:06 PM
KShaub103's Avatar
KShaub103
I just replace my factor R56 speakers with Memphis Car Audio-Power Reference. I have the basic sound package. After is Check my +-'s. I start to play some music. As I am play a CD I start to turn up the sound and it starts to buzz and crackle. The sound sucks. The sound at low normal listing levels is fine but when I try to turn up the sound it isn’t meeting it potential. I don’t know if replacing my amp would help but I am frustrated so please help. Thanks you
Old Jan 1, 2008 | 09:03 PM
Minidrivr's Avatar
Minidrivr
If you have the basic non hi-fi system, your car doesn't have an amp. The crackling is probably due to the speakers not getting enough power to properly drive them. The hi-fi system has speakers on the A-pillars and the amp is located on the passenger side of the trunk. I could be possible you have a lose connection or something grounding out causing the bad sound, but if that was the case it would be terrible at low volume as well.
Old Jan 2, 2008 | 06:38 AM
KShaub103's Avatar
KShaub103
Old Feb 9, 2008 | 07:28 AM
matty125's Avatar
matty125
I have standard sound as well. I replaced my speakers and actually had a hard time figuringout + an - on the fac wiring. I hooked it up how it sounded best and havent a problem. It sounds As if you have a wire grounded out on occasion. Did you insulate all your wires and also are the connectors tightly placed on the speaker posts? I do not have any problem pushing my 4 ohm speakers w/ 92 sensitivity and no amp. If I remember correctly, the higher the sensitivity the more effiecent the speaker is at converting power to sound....meaning more sound with less watts
Old Feb 9, 2008 | 07:46 AM
DyeLooper's Avatar
DyeLooper
Check my gallery, I have a sheet for +/- for the speakers with colors.
Old Feb 9, 2008 | 08:10 AM
matty125's Avatar
matty125
Sweet, thanks much
Dec 23, 2015 10:36 AM
marendt428
Nov 14, 2015 10:03 AM
marendt428
Aug 8, 2015 04:44 AM
tippin
Aug 5, 2015 08:43 AM
