Navigation & Audio Front Speaker Swap - First Try
Old Jan 27, 2008 | 01:53 PM
sunshine22's Avatar
sunshine22
I was successful in taking off the door liner, but I couldn't figure out how to swap out the speaker. The speaker I bought wouldn't fit (the screw holes didn't match) and I couldn't figure out how to hook up the leads.
Here's what I ordered.
http://www.crutchfield.com/App/Produ...2I&tp=97&avf=N
http://www.crutchfield.com/App/Produ...2C&tp=96&avf=N
When the 5.25s didn't fit, it didn't even try the 3.5.
What did I do wrong. Was this the wrong size? Can someone explain what I need to get the right size (maybe a model #) and then how to hook up the wire.
Thanks.
Old Jan 27, 2008 | 05:04 PM
Big K's Avatar
Big K
I think that a 6.5" will fit better. but I think that you will always have to do some mods for the new speaker to fit. Check out the thread that shows the wiring diagram.
Old Feb 9, 2008 | 04:31 PM
matty125's Avatar
matty125
You should get some plexi glass and make a mount bracket, it worked good for mine. Those 3.5 are way to small you WILL for sure need a custom mount for those, or try to find 4in
Old Feb 9, 2008 | 05:21 PM
Robin Casady's Avatar
Robin Casady
I used 6.5" and 4" Infinity Kappas. They fit fine. The 3.5" was very much too small. If anyone wants a pair of Infinity Kappa 32.7cf 3-1/2" 2-way car speakers...
I had to drill a couple of mounting holes for each, IIRC, but the speaker dia. was right at 6.5" & 4". However, the foam seal on the speaker cover grille (part of door panel) hit the rubber that connects the speaker cone with the bracket. The speakers came with a clear plastic ring that snapped over the speakers to protect this part in shipping. I snapped this onto the 6.5 speakers before putting the door panel back. They keep the foam off of the speaker, but still form a seal.
The wires have to be cut near the plug that goes into the factory speakers. Then either solder leads onto them, or use something like this:
http://www.crutchfield.com/S-BDXdAqA...spx?i=669PP502
You have to be careful with these that they can't flop around and cause a rattle with vibrations from the car or speakers.
I think it is the wires for the 6.5s that need to be fed back through the door to behind the speakers. There is a rubber plug that seems to just be filling a hole in the door. I put a hole in the middle of the rubber and passed the wires through it.
woodstudio
Mar 15, 2020 08:28 AM
ebowling
90
Aug 4, 2019 09:15 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
FLYM1N1
Aug 15, 2015 11:20 AM
OutMotoring
Aug 6, 2015 09:32 AM
