Navigation & Audio What are the sizes?
Old May 19, 2007 | 10:55 AM
navydave1974's Avatar
navydave1974
What are the sizes?
What are the sizes of the stock speakers in an 03 Mini? I'm looking to upgrade but not sure of the sizes without taking the panels off the front and back. Any help is appreciated!
Old May 19, 2007 | 07:40 PM
btallack's Avatar
btallack
6.5s in the front and 6x9s in the back if memory serves me correctly. 6.5s all around in the Cabrio.
Old May 19, 2007 | 11:16 PM
Giants9595's Avatar
Giants9595
It is 5.25s in the front but can be adapted to fit aftermarker 6.5s. The rear speakers are 6x9s.
Old May 20, 2007 | 09:24 AM
navydave1974
Thanks for the help! Now it's time to go shopping!
Old May 20, 2007 | 10:23 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
5.25" on the lower front doors for midrange/woofer or component speaker.
The stock speaker has a built in mounting ring. Using 6" speakers you can make your own ring to fit the door and fit the speaker. You can either use the existing door speaker grill or cut it out and do a top mount. The grill doesn't remove easily.
1 3/4" tweeter (1" tweeter will need adapter or top mount) on the upper front door. Tweeters do better when mounted as close to the ears or as superficial.
Rear seat side panel- standard 6x9 speakers. Since usually just fill in look at full range or 2 way speakers. Use stock grills.
Some pics (Ian at http://www.gbmini.net/G2/v/General/StereoPics/)
Front door opening for speaker with dynamat installed
MB Quart component speaker with crossover installed
Rear speaker opening
HK front speaker with ruler
HK front speaker
HK rear speaker
Variation - 8" sub in 6x9 rear opening
Doc Pain
Oct 28, 2015 07:09 PM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
WhinyR53
Sep 30, 2015 07:36 AM
BossyR56
Sep 28, 2015 11:33 AM
gnhovis
Sep 28, 2015 06:28 AM
