MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
specifics of changes to dsc?
Old Jul 12, 2006 | 04:13 AM
  #26
dmh's Avatar
dmh
The "how" is proprietary. The "what" is slip angle allowance. That's it. End of story.
Old Jul 12, 2006 | 07:13 AM
  #27
blalor's Avatar
blalor
Originally Posted by dmh
To sum up what MTH does to DSC: we allow for more wheel slip everywhere not just at take off. I.e., it activates less abruptly. All other information is proprietary.
What I'm hearing is "we do great things do DSC to make it better! you want it! ... no, we won't tell you what those great things *are*, however." This seems like a strange way to sell a product.
Old Jul 12, 2006 | 07:20 AM
  #28
dmh's Avatar
dmh
I cannot understand what seems to be the problem with the communication.
Slip angle: it activates at a higher force.
How MTH does this is not available to the public: it is proprietary.
Old Jul 12, 2006 | 07:30 AM
  #29
Dr Obnxs's Avatar
Dr Obnxs
I've had the mod for years....
don't worry about DSC not being there in the Oh Sh*t situations, it still is. The effects on the traction control are nothing short of fantastic.
For those of you demanding to know more about the changes, educate yourselves on how the system works, and then Don's answers make perfect sense.
Matt
Old Aug 28, 2006 | 08:30 AM
  #30
Guest's Avatar
Guest
Yikes!
I think the problem in communication is people seem to think DSC has something to do with traction. It has NOTHING to do with traction. You could spin tires all day in a burnout and DSC wouldn't do anything. DSC is a stability control system that corrects vehicle yaw in situations where individual wheels are slipping, and the nose of the car doesn't go where you want it to (Oversteer/Understeer/Spins/Fishtailing/etc).
ASC+T is a traction control system that cuts throttle input in a situation where the DRIVE WHEELS lose traction. Around a corner for instance, if you give it some gas and the wheels spin, engine power is reduced so you can maintain traction (Driving on wet roads, or in the snow.
Both of these systems are COMPLETELY different and have very little to do with each other.
DSC uses a yaw sensor and steering input sensors to determine the correct course of action, this is a safety only feature, and usually doesn't need to be turned off.
ASC+T uses the ABS sensors to detect varied rates of wheel spin between the drive wheels and reduces power to the wheels so you can maintain traction on slippery surfaces. A Limited Slip Diff will make this system a little less intrusive as well as Mini USA changed the software somewhat I believe. This system is primarily a convenience system, and doesn't always have a reason involving safety to be on (Sometimes it's unsafe... it may cut power while pulling into traffic, etc).
The problem is that these systems are tied together on the Mini (And most other cars), you cannot disable one or the other, it shuts down both systems when you hit your DSC button.
I believe what Don is trying to say is that the MTH file alters the input of the ASC+T system (Drive Wheel traction control ONLY) so that it is less intrusive, aka does not click on as fast, and when it does, it does so more smoothly rather than just cutting power completely.
No fighting, we're all fellow Mini dorks
Old Aug 28, 2006 | 11:28 AM
  #31
daflake's Avatar
daflake
Actually, what is said is correct as there is only one system now and it is called DSC (Dynamic Stability Control). It does, however, incorporate the older ASC functions but it is not called that any longer.... Just good ol DSC...
Old Aug 29, 2006 | 03:31 AM
  #32
blalor's Avatar
blalor
Not entirely true, daflake, unless they stopped offering ASC+T when you don't get the DSC option. DSC may be "newer", but it's also an option. The standard nanny is ASC+T.
Old Aug 29, 2006 | 11:35 PM
  #33
Cooper_Si's Avatar
Cooper_Si
Isnt it funny that MINI sells us these cars with ASC, DSC and all that jazz....and we go wooooo yes please on the options list, but at the end of the day people dont have a clue what they "actually" do. I think some people need to educate themselves (like the Dr. advises) then all will be apparent to what DMH is saying. He has answered the question and some seem to be beating him up for fun by silly snide comments...thats not what MINI WORLD is about. If people seem "unhappy" by his comments, then why not contact MTH direct ?
Just my opinion of course lol
Old Aug 30, 2006 | 03:10 PM
  #34
Dr Obnxs's Avatar
Dr Obnxs
To be fair to a lot of people
they know what these systems do, just not how they do it. Its the how that's needed to understand Dons comments.
Matt
Old Aug 30, 2006 | 04:07 PM
  #35
Canned Heat's Avatar
Canned Heat
Lots of Confusion Here...
I'm not sure why this is such a touchy topic.
There is nothing unusual about not sharing proprietary design information. You buy hundreds of products (including cars) that you will not be told about the specifics of because it would jeapordize the designers exclusivity. It is normal to explain the effects and benefits as a rule.
DSC like almost every street driving systems aimed at reducing driver work load and effort is implemented for the average driver. The average driver has a very low skill level as measured by advanced driver assessment sytems and therefore it is often of benefit to them. (this is a measured statistic and not a shot at anyone).
Conversely DSC is not more effective in advanced driving circles where it defeats some of the driving tecniques used to gain advantage both in racing and on the road. It is certainly true that if you believe it is better for you to have DSC on then that is a good decision.
Old Aug 31, 2006 | 02:02 AM
  #36
daflake's Avatar
daflake
Let me rephrase this...
ASC+T is a standard on the MCS, but not the MC from the beginning (06 models). When you add DSC, it integrates the entire system into one functioning unit and is no longer ASC+T but rather a bigger system with more features called DSC. If you want to break it down, fine, but if a person refers to the entire system as DSC, then that should be ok as really that is what it is.
Old Aug 31, 2006 | 02:04 AM
  #37
daflake's Avatar
daflake
DSC like almost every street driving systems aimed at reducing driver work load and effort is implemented for the average driver. The average driver has a very low skill level as measured by advanced driver assessment sytems and therefore it is often of benefit to them. (this is a measured statistic and not a shot and anyone).
Conversely DSC is not more effective in advanced driving circles where it defeats some of the driving tecniques used to gain advantage both in racing and on the road. It is certainly true that if you believe it is better for you to have DSC on then that is good decision.
Agreed!
Old Aug 31, 2006 | 09:05 AM
  #38
Canned Heat
Well explained.
Old Aug 31, 2006 | 09:16 AM
  #39
Dr Obnxs's Avatar
Dr Obnxs
IT's all just software...
sad, but that's the case with a lot of stuff now...
Matt
Old Sep 16, 2006 | 07:58 PM
  #40
El_Jefe's Avatar
El_Jefe
The only reason I would never get one of these aftermarket flashes is that it messes with DSC. I didnt pay 500 extra to have some company change it on me. I paid 500 for LSD though, and that works fine if you just flip off the DSC. DSC shouldnt be trouched, neither astc. That's just dangerous, stupid and irresponsible of an aftermarket company. I cant imagine an aftermarket having ACTUALLY run 1000's of car tests like bmw has for safety.
had to put my four cents in there.
Old Sep 16, 2006 | 10:09 PM
  #41
Jacob's Avatar
Jacob
What we really want
is what Chevrolet provides on the Z06, Active Handling plus Traction Control. "Active Handling" is the same as DSC, meaning oversteer correction, etc. Traction control is self evident. Corvette has a switch to deactivate both A/H and T/C, but by holding the switch down for 5 seconds, you can invoke "Competition Mode" which disables T/C but leaves A/H on. Great for the track.
Jacob
Old Sep 18, 2006 | 09:47 AM
  #42
El_Jefe's Avatar
El_Jefe
The asct system works to allow grip on snow. It is perfectly balanced to make sure the tires do not slip but keep a steady level of traction. Less than this really sux and is pointless to even call it astc. My best guess is that they took it out so can keep on DSC for safety on turns in bad condition and spin out for fun from standstills on roadways and on sharp banking turns in a racing setting. It stops the complaint people have about pulling out of some place fast and the engine cuts power. however, a simple flick of a switch stops this from happening, a lot nicer than messing with a safety system.
Tweaks to DSC I would understand as being possibly better if thoroughly tested. Astc is a much more simple idea that either stops tires from slipping on ice and snow or doesnt.
Old Sep 21, 2006 | 07:46 AM
  #43
SalemMINIDriver's Avatar
SalemMINIDriver
What sold me on DSC:
When we were MINI shopping I came across reference to fatal accident statistics from when Mercedes Benz's version of DSC was first introduced. Accidents involving fatalities for the stability control-equipped MBs were down 30% in Germany while rates remained flat for all other vehicles.
DSC has not intervened in the two plus years that I've driven MINIs. I wouldn't have a MINI without it as it is my belief that sooner or later I will encounter a circumstance where no amount of driving skill will allow me to safely avoid a collision while keeping the car miving in the direction I want it to. I'm also not naive enough to see DSC as a substitute for good judgement; at a certain point basic laws of physics rule, and you're GOING to crash.
Traction control in the MINI is another story. As applied in the MINI it would be just about perfect as a WINTER MODE. Just for kicks I would often stop in the middle of my parents' steep snow covered driveway, put the car in first, and floor it. Without fail, our MINI slowly ascends in a straight line as fast as the tarction afforded by our snow tires will allow.
Pulling into fast traffic from a stop, even on dry pavement, on the other hand it downright scary, and this is the only time that I switch the system off. As mentioned previously, it's also a bit of a kill-joy on fast exits to tight corners. I suspect that in my case this is more down to overly exuberant use of the throttle than is advisable in a short, light, FWD car in these situations. I take the blinking yellow light on the dash as a signal to work on smoother application of power.
A three-season ASC SPORT MODE would be very welcome if it could be implemented without affecting the DSC functionality. This should be doable as the two systems are triggered by different inputs (inconsistent yaw/steering wheel position vs. unequal front wheel speeds if I'm not mistaken).
Old Sep 21, 2006 | 07:50 AM
  #44
SalemMINIDriver
I'd love to see this applied to the MINI. Is there any word yet on how these systems will work on the '07+ MINIs? I've noticed that the new center stack row of toggles no longer includes a DSC/ASC switch.
Old Sep 22, 2006 | 07:14 AM
  #45
Dr Obnxs's Avatar
Dr Obnxs
But you are wrong here...
The traction control intervention on the Mini is downright scary. How many of us have gassed it to get into the flow of traffic, only to have the car loose pretty much all power, then you have to wait, and hope that the opening in traffic doesn't dissapear because you're half way into it! The modification I have to the traction control allow me to floor it through those situations, and even if there is a puddle, it keeps a good amount of power going to the wheels. It's frigging awsome, and is how the system should have come from the factory. Just getting base MTH for these features is well worth the $.
So, if BMW did all these tests to make the system good, why do we have a friggin scary system from the factory?
Matt
Old Sep 25, 2006 | 12:49 AM
  #46
Johan's Avatar
Johan
Matt
Agreed! MTH doesn't turn off the DSC(ASC) option, they tune it to work better with your mini. However I'm sure IF you ask MTH the can leave the DSC alone. Me personally I love it! It's one of the reasons I went with MTH in the first place and probably stay with MTH. For ME the factory DSC settings were just too touchy, especially once I started to mod and gain more HP. -- Johan
Old Sep 25, 2006 | 06:04 PM
  #47
El_Jefe's Avatar
El_Jefe
uh. if you are entering traffic you turn it off. every other reason to mess with DSC is retarded. off, or factory bmw settings are two safe options.
Old Sep 26, 2006 | 12:13 AM
  #48
daflake's Avatar
daflake
True, but now I don't have to mess with it at all. DSC is still there (have had it kick in), but it is not as sensitive. MTH did a great job of modding it.
navybsn
Oct 5, 2018 04:42 PM
pglgp1292
Aug 9, 2017 12:45 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Samhillrocks
Sep 29, 2015 12:55 PM
