MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
Throttle body and MTH tuner file?
Old May 20, 2006 | 07:01 PM
Maaij's Avatar
Maaij
Do I need do update my MTH tuner file after fitting a bigger throttle body?
Old May 21, 2006 | 04:51 AM
Johan's Avatar
Johan
Yes, no doubt! I had a mad flat spot after intalling the larger TB. After a new file it all basically went away. -- Johan
Old May 21, 2006 | 06:31 AM
Gr8Force's Avatar
Gr8Force
Any time you change even one power mod you'll want to get a new file.
Let us know how the the TB w/file goes. Enquiring minds want to know.
Old May 22, 2006 | 06:06 AM
dmh's Avatar
dmh
Save your money -- do NOT change the TB. The increased air flow will do nothing except mess up the computer. The bottle neck on the Mini is not on the intake side but rather the exhaust side -- the valves they are too small. But if you want to buy something that will improve the perfomance get a header or exhaust system.
Old May 22, 2006 | 09:56 AM
Maaij's Avatar
Maaij
I already got:
MTH header
Playmini exhaust
K&N Typhoon
Pilot Coil
Denso Iridium Plugs
Magnecor Wires
So you dont recommend me to buy the TB? Will there be no performance increase? Nothing at all?
You said it will mess up the computer. Is this a bad thing? Will it damage the engine?
hope you can help me
Old May 22, 2006 | 01:53 PM
haulinS's Avatar
haulinS
I'm not sure if you have an MCS or not but I would go with a 15% pulley before a larger TB for a greater performance improvement.
From what I've heard the performance gain of a larger throttle body is not fully felt until you go with P&P head/cam, header. this will open up the entire air passage from intake to exhaust. If you are only opening up the intake and the exhuast, but not the head, you still have a bottleneck. The larger TB will give you a minor perfomance increase and better throttle response but you will no doubt need an MTH update as many have reported a flat spot in the power band without an ecu update.
good luck and keep us posted.
I already got:
MTH header
Playmini exhaust
K&N Typhoon
Pilot Coil
Denso Iridium Plugs
Magnecor Wires
Old May 22, 2006 | 02:30 PM
Maaij's Avatar
Maaij
Thanks for the replys everyone.
Have contact MTH and they will update my file with the new mods. Hope to get everything ready next 2 weeks
wildwestrider
11
Jan 29, 2016 05:06 PM
pglgp1292
Oct 5, 2015 06:47 PM
semibreve42
Oct 2, 2015 09:06 AM
Sep 28, 2015 09:13 AM
Sep 25, 2015 12:32 PM
