Mini/MINI BUILDS Showcase your Build Talents.
ND's MCS R53 JCW build/progress
Old Sep 20, 2021 | 10:10 AM
  #201
nd-photo.nl's Avatar
nd-photo.nl
Went to a small meeting yesterday and brought my camera. I love the way the sound echoes over there :D
Old Oct 4, 2021 | 10:40 AM
  #202
nd-photo.nl
Finally was able to source a new set of carbon tips. The provided tips started falling apart, as the carbon weave was disintegrating. I think that is due to the fact that I heatwrapped the complete catback, but that is an assumption.
[edit]
Old Oct 5, 2021 | 02:30 AM
  #203
JerBear's Avatar
JerBear
I like those tips, they look more refined than the previous set. Also like how the dirty car makes the clean tips really pop :-D
Old Oct 5, 2021 | 06:30 AM
  #204
nd-photo.nl
Thx man, I like them too. Some tree somewhere nearby is blooming, I can wash it daily but I dont feel like it :P This was the third set btw...
1) ordered tips that were too long (stuck out way too much), they were 170mm in total
2) ordered 120mm tips (overall length), got 2 different tips delivered...
3) ordered these 120mm tips, custom size without any logos, finally delivered correctly :D
Old Oct 5, 2021 | 07:57 AM
  #205
JerBear's Avatar
JerBear
Sounds like the type of headaches I deal with when messing with exhaust systems lol. I've revised mine no less than 9 times now .
And we had these evergreens at our old house that would blow so much pollen out in the spring months that it looked like a yellow fog in the air!!! It was awful!
Old Oct 5, 2021 | 04:26 PM
  #206
nd-photo.nl
Ah speaking of which, after a month of delay my Simons "handy" silencer finally arrived (stainless steel shortage). I will start working on it thursday night. It has the same dimensions as the resonator, so should be straightforward. Also the Simons silencer does not require welding as I can just slide it on and use 2 exhaust clamps. Hopefully that will get rid of the highway drone...
https://www.bar-tek-tuning.com/simon...63-5-mm-silent
Old Oct 5, 2021 | 06:22 PM
  #207
JerBear's Avatar
JerBear
I ended up using the canister muffler that I had on the back at first as a resonator and welded everything else together. Its still a tiny bit louder than I'd like but it got rid of almost all the drone. That should work out good for you.
Old Oct 6, 2021 | 09:44 AM
  #208
nd-photo.nl
Nice! Thanks for the info. Im having good hopes for this
Old Oct 9, 2021 | 03:48 PM
  #209
nd-photo.nl
Was finally able to go to work! The Simons muffler has great build quality
Perforated insides
Simons muffler next to the resonator
Muffler in place!
The insides of the resonator, behind the perforated section, no material could be spotted (anymore?)
Had to buy a section of stainless pipe as I miscalculated hehe
And the end result beneath the car. Happy with the result, the drone has been reduced even further, but the overall exhaust sound as well. I will need to get used to that, as I was used to the pretty loud exhaust note (including pops and bangs). But for longer trips, this is the better choice.
Old Oct 10, 2021 | 02:34 AM
  #210
smschriefer's Avatar
smschriefer
When I saw the side by side I was thinking it looked shorter. Good to hear it wasn't too bad of a fix for length. Looks good and if it helps meet the end goal even better!
Old Oct 10, 2021 | 04:23 AM
  #211
nd-photo.nl
It is a little bit shorter haha! Luckily the fix was easily applied
Old Oct 10, 2021 | 09:30 AM
  #212
MCS4FUN's Avatar
MCS4FUN
Interesting updates! Surprised that a short silencer can (250mm / 9.8") would achieve such noticeable noise reduction results. As outlined in my (sig) thread topic, I replaced the new Miltek res-pipe with Miltek non-res-pipe version to gain additional clearance to top of tunnel and eliminate vibration rattles. Accomplished that but would prefer quieter in cabin under load (must talk fairly loud if with passenger when driving up steep grades). Modding my current non-res-pipe to insert same Simons can would be fairly simple but suspect Simons can OD (125mm / 4.9") is equivalent to Miltek specs, thus no gain in clearance. Yet another reminder "no free lunch" with performance mods!
Old Oct 10, 2021 | 10:53 AM
  #213
MiniManAdam's Avatar
MiniManAdam
Community Builder
Are those orangje or what ever brand name rear bumper inserts? I looooove the look of those and like them better than my actual real functional stock style inserts
Old Oct 10, 2021 | 10:56 AM
  #214
nd-photo.nl
The result is a combination as the soundproofing already was a big part of the solution. I would recommend you try that first, not that expensive and easy to try. How come you need more clearance?
Old Oct 10, 2021 | 10:57 AM
  #215
nd-photo.nl
I dont know the brand my man, they were already on the car when I bought it. Proper carbon GP inserts, looks much better than the stock look imho
Tweedbean
Mini/MINI BUILDS
24
Oct 27, 2020 09:11 AM
nd-photo.nl
Jul 17, 2020 01:51 AM
mlee4984
Mar 9, 2019 08:42 PM
pmsummer
Jun 10, 2013 04:15 AM
Albiecrazy
Feb 25, 2013 05:52 PM
