R56 60-0?
Old May 2, 2007 | 12:02 PM
familiarstranger's Avatar
familiarstranger
60-0?
Does anyone know the 60 to 0 time for the 07 MCS? I know the brakes are the R53 JCW's so they have some bite, I was just wondering if anyone had a time.
Old May 2, 2007 | 12:53 PM
laughbuddha's Avatar
laughbuddha
stopping distance
Road and track put it at 122 feet from 60 MPH. See the attached
http://www.roadandtrack.com/assets/d...pockets_dp.pdf
Old May 2, 2007 | 01:00 PM
r56mini's Avatar
r56mini
60-0 is not measured in time. it is measured in ft. Anything below 130ft is good.
Old May 2, 2007 | 01:33 PM
chows4us's Avatar
chows4us
I wouldn't be so concerned with distance. I would be more concerned with brake fade.
Old May 2, 2007 | 01:47 PM
r56mini's Avatar
r56mini
MINI is a lighter car that boasts good performance. Brake fade is something people talk about at the tracks. IMO, for the the everyday life situations, how far you travel after applying the brakes in an emergency situation is more critical. And that is why the car magazines print stopping distance. They comment on brake fade if they testdrive the car on the track because some readers expect them to. If the mag. writers only did on-street testdrives, some or many people won't take that particular mag seriously. What % of MINI owners go on the track?
Old May 2, 2007 | 01:54 PM
chows4us's Avatar
chows4us
Originally Posted by r56mini
MINI is a lighter car that boasts good performance. Brake fade is something people talk about at the tracks. IMO, for the the everyday life situations, how far you travel after applying the brakes in an emergency situation is more critical. And that is why the car magazines print stopping distance. They comment on brake fade if they testdrive the car on the track because some readers expect them to. If the mag. writers only did on-street testdrives, some or many people won't take that particular mag seriously. What % of MINI owners go on the track? In autoX, track pads don't work because the pads don't heat up as much. So the initial bite is more important for autoX and street.
I think a fair amount of ppl (not huge but fair) track their cars these days. But that aside, I'm willing to bet a couple of hot runs on the Dragon gets brake fade very easily.
If the R56 distance is more than the Mazda and it has the JCW brakes ... not so good if thats important. I have no idea what a really great number may be but I do remember, for example, MR2 numbers were 98 feet. I only remember because it was one of the few cars to break 100 feet.
If you drive hot in the twisties, brake fade can be very real ... and not fun.
Old May 2, 2007 | 02:16 PM
familiarstranger
Thanks everybody. I guess the correlation between the numbers 60 and 0 and time confused me.
Old May 2, 2007 | 02:36 PM
graphicjoe's Avatar
graphicjoe
Actually stopping distances can be presented in terms or time or distance. I've seen both, but distance is more common by far.
Joe
Old May 2, 2007 | 02:39 PM
Robin Casady's Avatar
Robin Casady
Did that article mention brake fade on the MINI as a problem? Anyone have fade problems at the Dragon? Or is it still too early for that?
Doesn't the braking distance have a lot to do with the tires? If you look at the tests on tirerack.com you find considerable variation between tires on one car.
Old May 2, 2007 | 03:04 PM
jasonsmf's Avatar
jasonsmf
If we are talking about one 60-0 stop and not repeated stops; there is zero performance advantage in the larger R56 (or R53 JCW) brakes over the smaller stock R53 brakes. The smaller brakes have more than ample stopping power to invoke lockup (ABS kicks in) even on hot sticky race tires- available tire friction is the limiting factor in this equation. Now, if we want to start talking repeated heavy braking application, the extra mass of the larger brakes will be an advantage by being less prone to fade.
Jason
ljmattox
Feb 10, 2012 07:47 PM
irishpunk
Tires, Wheels, & Brakes
15
Oct 22, 2011 09:02 AM
BostonR56S
Jan 28, 2009 05:52 PM
