Drivetrain holding up the motor;
Old Apr 30, 2007 | 04:09 PM
herbie hind's Avatar
herbie hind
soon it will be time to pull the head and pan . i was wondering if anyone has done this with the motor in the car. if so what did you use to rig the motor up? i'm thinkin' pull the pan probly then support the motor from underneath and then pull the head . is there a better way?
Old Apr 30, 2007 | 04:15 PM
SRTech's Avatar
SRTech
Why pull the pan?
Steve
Old Apr 30, 2007 | 05:00 PM
herbie hind
Originally Posted by SRTech
Why pull the pan?
Steve
i've got a bad compression reading on #4 when dry; but a wet test brings it right up . so i've got seized ring at best and bad piston and bore at worst. so while i'm specin' the bores and rings i 'll need to pull the pistons and rods . it's got a bit of a rod rap on start up sometimes too so it's just as well . so it's hold the engine up from underneath or weld up a support off the strut towers . or maybe someone's got a proven way .
Old Apr 30, 2007 | 05:22 PM
SRTech's Avatar
SRTech
I've always built wooden supports because they don't damage metal very easily. But I've done a lot of construction in the past so I have the tools and the wood so it's easy. What did you do to need so much work? Or did you just really enjoy your MINI?
Steve
Old Apr 30, 2007 | 05:56 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Since the main motor mount attaches to the block and not the head, the motor is mostly self-supporting. THe lower mount on the pan is a torque strut and can be removed with no problems. Unless you plan on pulling the crank or trans, there is no extra support needed.
Old Apr 30, 2007 | 06:01 PM
SRTech's Avatar
SRTech
Unfortunately, you have to remove that mount to get to the timing chain tensioner bolts.
Steve
potterstein
Dec 30, 2024 05:18 PM
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
KristaMcCoy
Sep 12, 2015 05:37 PM
Sep 2, 2015 11:15 AM
