Drivetrain holding up the motor;
soon it will be time to pull the head and pan . i was wondering if anyone has done this with the motor in the car. if so what did you use to rig the motor up? i'm thinkin' pull the pan probly then support the motor from underneath and then pull the head . is there a better way?
Steve
i've got a bad compression reading on #4 when dry; but a wet test brings it right up . so i've got seized ring at best and bad piston and bore at worst. so while i'm specin' the bores and rings i 'll need to pull the pistons and rods . it's got a bit of a rod rap on start up sometimes too so it's just as well . so it's hold the engine up from underneath or weld up a support off the strut towers . or maybe someone's got a proven way .
Steve
Since the main motor mount attaches to the block and not the head, the motor is mostly self-supporting. THe lower mount on the pan is a torque strut and can be removed with no problems. Unless you plan on pulling the crank or trans, there is no extra support needed.
Steve
UncDeo
Nov 4, 2019 04:08 AM
