Advise on 16" tire replacement for R56
Old Apr 18, 2007 | 11:47 PM
clubspec330i's Avatar
clubspec330i
I used to track but with 2 babies at home it is not going to happen anytime soon. However, when I drive the MCS to work or pleasure, I do drive it hard. I have selected a 16x7 wheel of choice with ET38.
Now, what tire should I get. I am thinking of 215/50-16 Avon Tech M500 or Dunlop Direzza. M500 is 81/tire vs. Direzza $61 + $50 rebate for set of 4 tires. Is the size ok or should I stay with 205 series?
Any suggestion for tires and sizes welcome.
Thanks,
Old Apr 19, 2007 | 07:14 AM
Mike02MCS's Avatar
Mike02MCS
I've been running Avon Tech M500 215/50-16 from Tire Rack for the last six months or so, no problems. Quiet, good rain performance. I have them on 16X7 Koenigs at about 16 lbs each. It's a good tire.
Old Apr 20, 2007 | 11:05 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks,
I think you are fine with that tire and rim size.
Most owners have stock 16x6.5" rims and choose 205/50-16 for a slightly smaller than stock sized outer tire diameter and light weight or lower cost and some choose 205/55-16 which weighs about the same as the 215/50 and is slightly taller than stock outer tire diameter which could increase risk of rubbing.
If you keep your stock suspension then your 16x7 rims fit the 215/50-16 just fine as is. Weight is 23 pounds so not too light but it's OK. 215mm width is fine for various 16" rims.
M500 is a good all around tire. Email or talk to Alex@tirerack.com for more info.
For a longer lasting all season tire consider the Kumho Ecsta ASX.
JamJam43087
Aug 16, 2015 02:02 PM
sabjcw
Aug 14, 2015 07:40 AM
Miniburb
Aug 7, 2015 03:45 PM
