Rocky Mountain Colorado, Utah, Wyoming, Montana, and Idaho
BMWCCA Autocross Classification Questions
Old May 8, 2003 | 06:37 AM
dave's Avatar
dave
pug poo picker-upper
With such issue as mods related to the supercharger, no stock camber adjustment, and odd stock tire sizes, the MINI (and the cooper S specifically) presents some questions in my mind about how to class the car for BMWCCA.
I'd appreciate your comments on these.
BMWCCA points assessment: Engine
Upgraded Chip or Software [3 points]
Non-Stock Air Intake (cone filter, larger carb, HFM, cold air intake) [3 points]
Carburator to Fuel Injection update [8 points]
Upgraded Cam Shaft(s) [13 points]
Forced Induction (SuperChargers, TurboChargers, etc.) [15 points]
Engine Swaps (Must be BMW Engine and Chassis) [20 points]
    BMWCCA points assessment: Suspension and Brakes
    Aftermarket or upgraded Springs (Coilovers or springs) [4 points]
    Aftermarket or upgraded Swaybars [4 points]
    Aftermarket or upgraded Shocks [3 points]
    Non-Stock Camber adjustment of any type [3 points]
    E36 X-Brace [2 points]
    Strut Brace front OR rear [2 points]
    Larger than stock Brake Rotors and/or non-stock Brake Calipers [3 points]
      BMWCCA points assessment: Driveline
      Non-Stock Gearbox [5 points]
      Non-Stock Final Drive [5 points]
        BMWCCA points assessment: Wheels and Tires
        Wheel diameter larger than stock size [2 points]
        Tire width between 19mm and 30mm over stock size [5 points]
        Tire width 30mm or more over stock size [8 points]
        Race compound tires (Treadwear rating less than 140)
          BMWCCA points assessment: Chassis and Bodywork
          Wheel wells cutout or widebody kit [3 points]
          Any lightening of body or interior (race seats, body components) [6 points]
            BTW, I'm really starting to think I should register for BS with the following:
              Without the voluntary assessment for the pulley, I come out at 113 ( CS )
              With the voluntary assessment for the pulley, I come out at 116 ( BS )
              _________________
              cranes folded: 680 goal: 1000
              YahooIM: denvermini
              Let's Motor More
              Old May 8, 2003 | 06:57 AM
              ficcion's Avatar
              ficcion
              They mention "stock diameter" for the tire set up. The Falken is actually about the same diameter as stock (slightly smaller).
              I see no need for point assesment if I am understanding this correctly.
              Old May 8, 2003 | 07:01 AM
              dave's Avatar
              dave
              I think the diameter comment is about running 18's on a car that comes with 16's.
              Or say in the case of the MINI: The cooper comes with 15s and 16s, so running 17s would be an assessment. The Cooper S comes with 16s and 17s, so using 18s would be an assessment.
              That's my take on the diameter issue. The falkens I think get points for the width, not the diameter.
              Old May 8, 2003 | 07:08 AM
              ficcion's Avatar
              ficcion
              But the width of the falkens is only 10mm over the stock 205's right. (Cooper S)
              Bmw says between 19mm-30mm over stock. (Kind of weird wording I must say.)
              I am sure with time we will get sime more specific rules for the MINI.
              And I am sure BS might not want us beating all their cars in that class either
              Old May 8, 2003 | 07:10 AM
              dave's Avatar
              dave
              MINI stock: 195 / 55 R16
              Azenis: 215 / 45 R16
              that's how I'm getting the 20 mm difference. The 205 width is for the 17" wheels.
              Old May 8, 2003 | 07:13 AM
              ficcion's Avatar
              ficcion
              SCCA considers 17" 205/45/17 stock class for cooper S, right?
              Old May 8, 2003 | 07:14 AM
              ficcion's Avatar
              ficcion
              Oh I see comparing 16" to 16".
              Ok.
              Old May 8, 2003 | 07:15 AM
              ficcion's Avatar
              ficcion
              It will all play out in the end.
              Let's race until then. :smile:
              Old May 8, 2003 | 07:19 AM
              dave's Avatar
              dave
              Well put Kelly. :smile:
              I guess all I'm trying to figure out here is at what point we shouldn't be racing in the same class as possibly stock MINIs (who leaves their MINI stock?).
              Old May 8, 2003 | 07:24 AM
              ficcion's Avatar
              ficcion
              There is no doubt there are some discrepancies.
              I am sure we can touch base with the BMW crew and make it more precise for the following year.
              My guess is we are a little to far into it this year to change things around.
              Your thought process is dead on though. Thanks for the insight.
              :smile:
              Old May 8, 2003 | 09:14 AM
              dave's Avatar
              dave
              I personally believe there should be an assessment for the pulley. It just doesn't seem right that a mod to the engine that makes more power than the intake and comparable power to the ECU gets no points assessed. Another factor is the 15% reduction on the pulley in SCCA would automatically put the MINI in SM (street mod). On the other hand, there are no points added for a non-stock exhaust and the pulley is adding similar power to the magnaflow/quiksilver (12-15 hp).
              I think I'm chasing my tail a bit there.
              Old May 9, 2003 | 09:25 PM
              dave's Avatar
              dave
              From Jeff Sherrard (RMC BMWCCA rules committee)
              If a car moves from one class to another, times/points do NOT move! There needs to be 4 finishes in a class to qualify for a season trophy.
              Any points changes would become effective this winter season. I won't make any changes during the summer season.
              jeff
              _________________
              cranes folded: 687 goal: 1000
              iclancy82
              Jan 2, 2021 08:59 PM
              donniedarko
              Oct 21, 2015 01:15 PM
              rob&JCW
              Sep 10, 2015 12:06 PM
              Accessory Products
              Sep 9, 2015 10:29 AM
              Robree
              Sep 9, 2015 08:43 AM
