R56 Turbo shutting down?
Old Mar 1, 2007 | 06:36 PM
daffodildeb's Avatar
daffodildeb
What's the humming sound I hear after I shut off the engine? It's way cool, sort of like a jet engine spooling down--is it the turbo?
Old Mar 1, 2007 | 06:38 PM
bamatt's Avatar
bamatt
Worthless answer here from me, a totally mechanically challenged NAMer but...
I think it's the fan that cools your turbo
PGT's Avatar
PGT
it's teh pump running coolant and oil through the turbo to cool it down. Proof positive that everybody who insists on a turbo timer should send their money my way instead (it will do as much good, and hey! if you want to give money away, might as well be to someone who'll use it for something that actually us useful).
Old Mar 1, 2007 | 06:40 PM
bamatt's Avatar
bamatt
hey!! at least I was in the ballpark
sorry but I am watching Are You Smarter than a 5th Grader on TV & I am feeling the uncontrollable urge to answer questions
Old Mar 1, 2007 | 06:45 PM
Motor On's Avatar
Motor On
Also boosted engines are often known to be programed to have the engine cooling fan run for a given amount of time to help offest much of the heat created from Turbos and SCs.
reelsmith.'s Avatar
reelsmith.
This was covered pretty well here:
https://www.northamericanmotoring.co...t=92948&page=2
dean.
Old Mar 1, 2007 | 06:51 PM
PGT's Avatar
PGT
yes, most any aluminum block motor will generally run a fan but the OP mentioned a 'jet engine' sound. That's a pump running and not a fan.
Old Mar 1, 2007 | 06:53 PM
Motor On's Avatar
Motor On
Well I now my R53's cooling fan can easily be described as "jet engine" (as I have likened it to that so was just throwing it out there as a possible source of the noise.
Old Mar 1, 2007 | 07:04 PM
daffodildeb
Is it true that we're supposed to idle the car after running "spiritedly" in order to cool the turbo? Or is that just an old wives' tale?
Old Mar 1, 2007 | 07:08 PM
RA080624's Avatar
RA080624
turbo timer besically fans cool the turbo so u dont mess it up
Old Mar 1, 2007 | 07:17 PM
PezRadar's Avatar
PezRadar
Man lots of repeated threads lately =\
Old Mar 1, 2007 | 11:03 PM
Warped1966's Avatar
Warped1966
IMHO, if you drive a turbo car hard in the last mile or so before turning it off, it could never hurt to idle it for a minute or so to help cool the turbos even though the Mini's auxiliary water/oil cooling pump will still run for a bit after shutdown.
Old Mar 2, 2007 | 02:48 AM
Skuzzy's Avatar
Skuzzy
Generally speaking, it is a good idea to run the engine a minute or so after being on the turbo for a bit. If you do some normal driving after being on the turbo, that should cover it.
It just helps to remove the excess heat generated by the turbo from all parts of the engine, including the turbo.
Colt45Magnus
Aug 27, 2024 05:03 AM
Pker
Apr 11, 2017 12:14 AM
KinetechMW
Jan 22, 2016 09:04 AM
Mb460
35
Sep 18, 2015 06:46 AM
Sep 3, 2015 01:45 PM
