Urethane headlight guards
Old Jan 1, 2007 | 03:07 PM
MGCMAN's Avatar
MGCMAN
Old Jan 1, 2007 | 03:18 PM
COR BLMY's Avatar
COR BLMY
Old Jan 1, 2007 | 03:22 PM
89AKurt's Avatar
89AKurt
Old Jan 1, 2007 | 03:30 PM
BlueBonnet's Avatar
BlueBonnet
Not so wordy Kurt, if you please.
Old Jan 1, 2007 | 03:32 PM
mcdbrendan's Avatar
mcdbrendan
Old Jan 1, 2007 | 03:35 PM
Motor On's Avatar
Motor On
Old Jan 2, 2007 | 10:48 AM
nixjosh2's Avatar
nixjosh2
Old Jan 2, 2007 | 11:23 AM
Motor On's Avatar
Motor On
Originally Posted by nixjosh2
Old Jan 2, 2007 | 11:35 AM
yumhaggis's Avatar
yumhaggis
Understood.....
Old Jan 2, 2007 | 12:06 PM
kenchan's Avatar
kenchan
Old Jan 2, 2007 | 12:38 PM
ImagoX's Avatar
ImagoX
+1!
Old Jan 2, 2007 | 02:57 PM
Jakemini's Avatar
Jakemini
Yikes, minimalists!
Old Jan 2, 2007 | 03:13 PM
kenchan's Avatar
kenchan
i use the Xpel headlight protector if anyone cares.
use a heat lamp to make them soft, then apply using water only.
then squeegee out the water, toast it for about an hour under the
light. the clouding will completely dissappear in about 2-3 months.
just the way it is.
the reason why you want to use water is because you need
to keep your fingers wet with water, otherwise you leave
finger prints on the adhesive side.
hope this helped somebody!
Old Jan 2, 2007 | 03:25 PM
Motor On's Avatar
Motor On
just the way it is.
Now you gone done and ruined it
Old Jan 2, 2007 | 03:57 PM
kenchan's Avatar
kenchan
oops.
Old Jan 2, 2007 | 04:43 PM
NMgokart's Avatar
NMgokart
Old Jan 3, 2007 | 05:11 AM
Benja0901's Avatar
Benja0901
Old Jan 3, 2007 | 05:26 AM
rivet's Avatar
rivet
Umm ...
Old Jan 3, 2007 | 05:35 AM
mini pooper's Avatar
mini pooper
Here is what they look like installed:
Old Jan 3, 2007 | 09:30 AM
thulchatt's Avatar
thulchatt
Who cares about the lights, what about the blond?
Old Jan 3, 2007 | 10:21 AM
COR BLMY's Avatar
COR BLMY
I like it (the blond and the lights)
I am in California and know that the MAN doesn't really like tinted ANYTHING
I am CR and have ruby tail lights so I was thinking about going euro and doing YELLOW
and blacking out the rings
any help locating the yellow and what about the rings do I paint or cover some how??
Old Jan 3, 2007 | 10:26 AM
eVal's Avatar
eVal
Like this?:
https://www.northamericanmotoring.co...light=jaundice
Be careful with the colored laminex stuff though, I recall people reporting it melting on their fogs awhile back.
I had the Stongard headlight film on a couple of BMWs and it worked well - very thick, really protected the lamps and no melting.
Old Jan 3, 2007 | 10:31 AM
mini pooper
Cor Blmy,
Thanks! So far I have not had any problems with the "MAN". I have "everything" tinted. My wife (the blond) got a perscription from her doctor for tinted windows to prevent UV rays. I keep a copy in the glove compartment.
That helps with the window tint issue, but I am sure that won't fly for the headlights.
I painted my headlight basils, but I understand from Peter at M7 that someone has developed and sells a vinal cover. I think I saw this somewhere on a post here on NAM as well.
My taillights are euro-blackened.
Old Jan 3, 2007 | 10:44 AM
kenchan's Avatar
kenchan
really? i have the laminex yellows on my fogs (since 2003) and no
issues melting...
Old Jan 3, 2007 | 10:57 AM
eVal's Avatar
eVal
issues melting...
I know your Mini is your weekend car, perhaps you don't run the lights on long enough to have issues? In any case, I just mention it because I recalled seeing it come up here and I think maybe on BMW boards in the past. I did a search and here is one thread where melting was mentioned:
https://www.northamericanmotoring.co...hlight=lamin-x
Fwiw, I think this is the product page with the melting point as 300 degrees F:
http://www.lamin-x.com/info-technical.php
