Roll Squeak. Roll Squeak.
Old Dec 26, 2006 | 06:37 PM
Ledlung's Avatar
Ledlung
Hi folks,
Our 2004 JCW has been making an annoying sound that I only hear while rolling slowly (especially in parking lots with other cars that echo the sound). It sounds like a tire rubbing against a shock or something. Kind of a wet rubbery squeak or moan mixed with a bit of grinding.
Clutch in or out doesn't matter. It either disappears as we go faster or other sounds get so loud I can't hear it any more.
I first thought it was brake rotor/disk related, but I've jacked up all four sides and can't replicate the noise when I spin the wheels. So it's only when there's load on the suspension, I guess.
Could it be the runflats? Stock tires, second set. Probably about 20K on them.
PS: This car has already gone through a wheel bearing. I can't remember which one, but I'm hoping it's not that or a CV joint. I figured I'd hear something, if it was, when I spun the wheels while it was jacked up.
Thanks for any thoughts!
Old Dec 26, 2006 | 07:36 PM
Motor On's Avatar
Motor On
ITs an 04 we're at the end of 06 I think its time to lobe the rear sway bar Little grease on the two mounts should do the trick.
Old Dec 26, 2006 | 07:45 PM
namwob's Avatar
namwob
If you were in a damp enclosed parking garage with cold tires, I'd say it was probably just talking tires. Bit of grinding? I don't know. But I will say this; stop buying runflats & get some decent tires.
Old Dec 26, 2006 | 07:52 PM
Motor On's Avatar
Motor On
You do know there are decent run-flats out there as well as some crappy non-RFs right?
USNAE2
16
Jun 17, 2022 07:17 AM
Filmy
15
Sep 26, 2015 07:04 PM
beasleyboy
Sep 24, 2015 09:22 AM
joedotmac
Sep 20, 2015 05:37 PM
PelicanParts.com
Sep 16, 2015 12:27 PM
