Squeeky shifter
Old Dec 21, 2006 | 08:50 PM
afnos's Avatar
afnos
Squeeky shifter
Go figure. My warranty goes away and crap starts to fall apart.
When I shift from 1st to 2nd there is a squeek as the shifter passes neutral. It is definitely coming from the shifter shaft. Is there an easy way to get some grease in there or another good way to lube it (lube the shaft...te he he )?
Old Dec 21, 2006 | 09:00 PM
002's Avatar
002
Just pull up the shift boot ring. You'll figure out the rest. Make sure that the guide pins are aligned before drive the ring back home. Oh, and try to control yourself around the lube.
RobbyD
Jan 29, 2019 01:22 PM
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
aldito2
Sep 30, 2015 10:44 AM
