R50/53 Odd Smell
Old Dec 19, 2006 | 03:35 PM
Jtrem's Avatar
Jtrem
Odd Smell
Yesterday I had a werid problem with my Mini not responding to my shifting (went into gear, but the gear change didnt effect the RPMs) There was an odd burning smell after It did that. I can't really explain the smell. It wasn't a rotten smell, or burning rubber smell. IT was really odd. My car drives fine now, no signs of a bad clutch or anything. However, it still smells odd (not as bad as when it first happend, but still noticable) Do you think my clutch could have burned alittle that night and Im still smelling alittle of it. Or do you think its something wrong with my engine? Im at a total loss right now. I can't take it into the dealer untill after christmas, because of the crazy week I have. So I be over concerned with it right now? The car drives fine no signs of problems accept for the smell.
Old Dec 19, 2006 | 03:39 PM
Motor On's Avatar
Motor On
Sounds like your clutch is dying/slipping and getting its life shortened
Old Dec 19, 2006 | 04:02 PM
kapps's Avatar
kapps
To test if it's a slipping clutch, floor it when your going down the highway. If the rpms rise fast, then it's slipping.
Old Dec 19, 2006 | 04:03 PM
Jtrem's Avatar
Jtrem
ill get it checked out/fixed after christmas. For now Ill drive my buddy's M3 while hes away!
Old Dec 19, 2006 | 04:06 PM
Motor On's Avatar
Motor On
lolz Its a nice car, but its just not the same
Old Dec 19, 2006 | 04:26 PM
A S K's Avatar
A S K
how good have you been....if bad than expect the worse, if good than you gots nothing to worry about since Mini-Clause will take good care of you in this time of festive season.
Merry Mini-mas!!!
Old Dec 19, 2006 | 07:36 PM
mhawker's Avatar
mhawker
Clutch smell is kind of a musty brake pad smell. Sort of like you were dragging your brakes..... over a skunk.
Old Dec 19, 2006 | 08:00 PM
Jtrem's Avatar
Jtrem
I had a friend who works on cars check it out. He drove it and said the clutch seams fine and checked the engine out. He said everything looks to be fine. He said from what I say that the clutch slipped and I burned it alittle. He told me not to worry unless the clutch pedal is sticking or its tough to put the car into gear.
Old Dec 20, 2006 | 06:41 AM
BRGPA's Avatar
BRGPA
I went to a Christmas light display a week and a half ago, and spent about an hour slipping the clutch as I crept uphill behind other vehicles. The clutch smell afterwards was terrible, and I thought it was completely fried although it worked fine. Two days later it still was stinking up the garage, but the smell dissipated over time. It seems fine now- only a hint of smell if I really give it the sniff test, so hopefully your situation will resolve itself, too. Clutch replacement could be big $$. Good luck.
drrigg
May 27, 2022 03:31 AM
eMINI of the State
Oct 2, 2015 03:12 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
daviday
Sep 25, 2015 01:31 AM
Sep 2, 2015 09:05 AM
