Wheels didn't clear BBK!
Old Dec 2, 2006 | 04:15 PM
UKSUV's Avatar
UKSUV
I'm so upset right now...well not as much now. I just went and purchased some 5mm spacers. They barely fit now! By like a mil or so. I don't even think the 3mm's would work. I have 18x7 Exel TZ-10's +42 Now, I need to track down longer tuner style wheel studs that are 5mm longer. Boy, the Stoptech's look schweet. Any ideas?
Old Dec 2, 2006 | 04:35 PM
vader's Avatar
vader
I wouldn't drive with the stock length bolts and 5mm spacers. I don't think it's safe.
Old Dec 2, 2006 | 04:39 PM
not-so-rednwhitecooper
5mm spacers is fine with stock lugs, but thats as wide as i would go on stock lugbolts.
Old Dec 2, 2006 | 04:48 PM
MiniMaxx's Avatar
MiniMaxx
Sorry to rain.....but I almost bought into a similar situation. I have the JCW brakes and was trying to buy a certain 16" wheel/tire combo (I forget which) with 3ml clearance and Alex/TireRack pointed out that a small rock could cause major damage if caught in the gap! Just what I was told.
Old Dec 2, 2006 | 04:52 PM
UKSUV's Avatar
UKSUV
So, from what I can gather...I need: Tuner Style (thin) bolts. M12x1.5x35. Stockers are I guess 30mm.
Old Dec 2, 2006 | 08:52 PM
UKSUV's Avatar
UKSUV
So anyways...Thanks to Kalbone, he had some longer Gorilla brand bolts. Now, onto my next saga. 1-Can't get my rt front caliper bracket bolts loose. So I moved to the back. 2-I get the new ST rotor on and went to go change my SS brake lines and it turns out my buddy ordered the WRONG SET!!!!!
I am a feb 03 build and he got the ones for May 03-current!! DAMN!
Old Dec 2, 2006 | 09:05 PM
UKSUV's Avatar
UKSUV
This brake thing is starting to become a drag...I'm moving on to putting up the X-Mas tree and decorating the house.
Old Dec 3, 2006 | 08:31 AM
deemotored's Avatar
deemotored
I hear if you go gold, it all works out.
Old Dec 3, 2006 | 08:40 AM
Duck360198's Avatar
Duck360198
Should have gotten a Cooper S!!!!!!! LOL You'll figure it out Justin!
Old Dec 3, 2006 | 08:43 AM
deemotored's Avatar
deemotored
Tru dat!
Old Dec 3, 2006 | 08:54 AM
Larry Clemens's Avatar
Larry Clemens
Bbk
Which BBK?
Old Dec 3, 2006 | 09:05 AM
MSFITOY's Avatar
MSFITOY
Yeah Spence...shoulda check Stoptech's profile first
I use ProMini's 50mm stud conversion...
Old Dec 3, 2006 | 09:44 AM
UKSUV's Avatar
UKSUV
Funny ha ha...That's what I got the LEFT side to look like.
Old Dec 3, 2006 | 09:47 AM
kenchan's Avatar
kenchan
just get some 7-8mm spacers with new lug bolts.
dremel the rear fender arch. done
if it was me, it would be an excuse to get some RGR's.
Old Dec 3, 2006 | 10:00 AM
ScuderiaMini's Avatar
ScuderiaMini
totally agreed
Old Dec 3, 2006 | 10:13 AM
UKSUV's Avatar
UKSUV
The only problems I have now are 1-I can't finish the right side, 2-I have the wrong brake lines. I solved the clearance issue.
MSFITOY's Avatar
MSFITOY
They make 7-8mm spacers? I thought that was impossible due to the hub center's thickness? 10mm spacers are the next step from 5 as it has it's own hub center...
Old Dec 3, 2006 | 06:54 PM
UKSUV's Avatar
UKSUV
Your starting to confuse the crap out of me.... H&R does make an 8mm hubcentric ring for the mini. Then it goes to 10 then 15. I bought a 5mm. 5mm and less do not have the hubcentric capability.:impatient
woodstudio
Mar 15, 2020 08:28 AM
Dec 23, 2015 10:36 AM
thebordella
Aug 31, 2015 01:37 PM
StuRat
Aug 24, 2015 06:24 PM
ki7hy
Aug 12, 2015 07:07 PM
