215/45R17 or 215/40R17
Old Nov 20, 2006 | 03:36 PM
curv872's Avatar
curv872
I will soon be replacing my runflats with Azenis RT-615's.
The question is, which size?
The 45's are .3 in taller than stock.
The 40's are .5 in shorter than stock.
Other differences are weight (the 45's are almost 2lbs heavier) and the 40's have a reinforced sidewall (which may create a harsh ride).
Any thoughts? My car is not lowered, so I am a little worried the the 40's will leave too much of a wheel gap.
Old Nov 20, 2006 | 04:52 PM
draggonmann's Avatar
draggonmann
I am running BFG KDW2 215/40/17s and my MINI was lowered 1.25". I didn't have any problems and I liked the look. I just put the stock springs back on for winter ( don't want to be a MINI snow plow) and after looking at it can't wait for spring to get here.
Old Nov 20, 2006 | 05:13 PM
XAlfa's Avatar
XAlfa
I just switched from stock 205/40 runflats to conventionl 215/45s. Torque loss is imperceptible, but ride is much smoother. Unless you are obsessed with lowering your gear ratios, I would probably go with the 45s.
Old Nov 20, 2006 | 05:52 PM
Longboard Mini's Avatar
Longboard Mini
If your car is srteet driven go with the 45's.
I have had three sets of 215 x 40's. I really like my new 45 series Kumho MX tires. They stick amazing and the ride is so much smother then the 40 series.
Here is a pic!
Longboard
Old Nov 20, 2006 | 06:12 PM
Wake|MCS's Avatar
Wake|MCS
I like the shorter sidewall of the 40 series tire so I went with 215/40 Falken Ziex 512's.. I love the look, now I'm just trying to get some m7's for the drop. BTW, I don't find the ride harsh at all. I'm coming from 205/40 Yokohoma Parada Spec 2's though.
Old Nov 20, 2006 | 06:45 PM
JSWMCS's Avatar
JSWMCS
rotational weight can cause big exceleration penaltys!
i went with the toyo proxis T1-S and 12.7lb wheels. what a difference in butt dyno!
Old Nov 20, 2006 | 07:49 PM
FUEGO's Avatar
FUEGO
We're running Kumho SPT 215/40-17 on O.Z. Ultraleggeras on my wife's MCC and have been very happy with them. The ride is much better than the Dunlop 9000 Sport RFs on S-lites they replaced. I also believe the 215/40 will be closer to stock diameter (of the 205/45-17) so your speedo stays close to stock.
Old Nov 20, 2006 | 07:58 PM
jymontoya's Avatar
jymontoya
235's! ::
Old Nov 20, 2006 | 08:00 PM
justintime's Avatar
justintime
I am running 205/45-17 and am not pleased. stick to 215/40 if u plan to drive comfortably
Old Nov 20, 2006 | 09:21 PM
XAlfa's Avatar
XAlfa
Actually, 215/45 is closer to stock, fwiw.
Old Nov 20, 2006 | 09:45 PM
FUEGO's Avatar
FUEGO
Well - we are both off - for Kumhos anyways. The 215/40 diameter is 23.8", and the 215/45 is 24.6" where the stock 205/45/17 Dunlop Sport 9000 are 24.2 - right in the middle So one will make the speedo read a bit fast and the other a bit slow.
Old Nov 21, 2006 | 01:39 AM
MCSJCW's Avatar
MCSJCW
Hello
The Stock diameter is 24.4".
Also I want to change the Run Flat and one of my greaters doubts is the measure of the tires (205/45 or 215/45), if want, see here (https://www.northamericanmotoring.co...t=84431«) and give yours opinion.
Best Regards
Old Nov 21, 2006 | 06:43 AM
eddiee46's Avatar
eddiee46
I am on Falken Azenis ST115s 215/40/17... love them
Old Nov 21, 2006 | 07:00 AM
geowit's Avatar
geowit
I'm on my 2nd set of 215/45-17s. The 1st were Dunlop FM901s and currently General UHPs. According to my GPS, my speedo still runs 1-2 mph FAST.
Old Nov 21, 2006 | 07:12 AM
camminich's Avatar
camminich
I agree with the thought if you are looking at normal or spirited driving then the 45s are the best bet. I switched to 215/45 R 17 Pirelli PZero Nero on S-Lites, and I love them. Much smoother ride with the slight added height. I have never had any problems with rubbing.
Now that said, I don't think I would do a lot of auto-crossing with these tyres. And if I ever did lower my MINI, I think I would be rubbing.
Old Nov 21, 2006 | 07:53 AM
curv872's Avatar
curv872
Thanks for all of the reply's.
Has anyone had direct experience specifically with the Falken Azenis RT-615's in both sizes? (215/45R17 vs. 215/40R17)
Old Nov 21, 2006 | 07:54 AM
curv872's Avatar
curv872
That looks awesome! I imagine the 45's would right at home on stock height MINI too.
Old Nov 21, 2006 | 07:56 AM
curv872's Avatar
curv872
Originally Posted by jymontoya
235's! ::
Tell me more. Are aftermarket wheels necessary for 235's?
Did you have to roll the fendors to prevent rubbing?
Do you have any pictures?
My previous car (E36 M3) had 235's on 17x7.5 wheels.
How wide are the MINI's wheels?
Old Nov 21, 2006 | 08:16 AM
MINIATIC's Avatar
MINIATIC
I went with cooper Zeon tires and also change to lighter wheels. I went with 205/40 R17 and the ride is much better, took a couple weeks to get use to the steering feel.. I love it!! better than driving the stock anchors(runflats)
Old Nov 22, 2006 | 07:04 PM
jymontoya's Avatar
jymontoya
Probably.
Only if you lower more than an inch. Or you can dial in a touch of camber in the rear.
Pics: http://picasaweb.google.com/jymontoya/My_mini
Mini's are usually 17x7.
Old Nov 24, 2006 | 06:59 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Probably.
Nice pics, they always help when evaluating mods.
Thanks!
Old Nov 24, 2006 | 09:02 AM
Duck360198's Avatar
Duck360198
Will the car rub if lowered with a 7.5" wheel and running the 45 series tire???
Old Nov 24, 2006 | 11:43 AM
cooldaddy's Avatar
cooldaddy
depends on how much lower the car is and perhaps more importantly the offset of the wheels...
vbmike
Oct 15, 2015 04:32 AM
mini_macky
Tires, Wheels, & Brakes
Jul 29, 2009 10:21 PM
technoticmedia
General Discussion
Jul 27, 2009 10:31 AM
Hot_Pepper
17
Apr 27, 2007 11:28 AM
