Suspension Polyurethane Bump Stops?
Old Oct 25, 2006 | 10:09 AM
jymontoya's Avatar
jymontoya
Can anyone point me to where I can buy some good quality polyurethane bumpstops. Pics of them would help a lot too.
Thanks!
Old Oct 25, 2006 | 11:24 AM
SayGoodbye's Avatar
SayGoodbye
Thanks!
http://www.mossmini.com/Shop/ViewPro...4&SortOrder=14
Old Oct 25, 2006 | 11:47 AM
meb's Avatar
meb
I would avoid these like the plague!!!
Old Oct 25, 2006 | 01:27 PM
obehave's Avatar
obehave
Hard bump stops are generally considered to be not a good idea.
Old Oct 25, 2006 | 02:59 PM
meb's Avatar
meb
They're in a lot of kits, including the one I currently have. They're probably quite durable...more so than rubber. Can you determine hardness? If so,perhaps my original reply was too quick...I should know that there is more than one correct answer.
I would consider investigating the progressive type bumpstops found in may of todays suspensions - these are typically not, if ever, made from poly. I began to look at these from an aftermarket perspective a while back. I sort of lost interest because I wasn't getting anyhwere with anyone.
I suggested Megan look at these a while back too, because of a lack of suspension travel. These would have potentially allowed their kit work a bit better...
Michael
Old Oct 25, 2006 | 03:25 PM
SayGoodbye's Avatar
SayGoodbye
Disclaimer...
...I know next to nothing about suspensions...I'm just a search monkey!
Old Oct 25, 2006 | 07:15 PM
jymontoya's Avatar
jymontoya
Thanks everyone!
Anyone know where to find progressive bump stops?
Old Oct 25, 2006 | 08:50 PM
kurvhugr's Avatar
kurvhugr
Ground Control has a few.
Old Oct 25, 2006 | 08:57 PM
SayGoodbye's Avatar
SayGoodbye
Thanks everyone!
Search Monkey here...probably won't help, but here's a link to stops for a classic: http://www.minimania.com/web/Item/AH.../InvDetail.cfm
Old Oct 25, 2006 | 09:44 PM
MarioKart's Avatar
MarioKart
Vendor
I hate my rear poly rear bump stops, THEY SQUEAK! I have adjusted them a few times but they keep sqeaking, I think I 'm going to change them out this weekend.
M
Old Oct 26, 2006 | 03:01 AM
onasled's Avatar
onasled
M
Old Oct 26, 2006 | 06:28 AM
obehave's Avatar
obehave
Originally Posted by onasled
Puzzled by the "adjusted" are you?
Me too
Old Oct 26, 2006 | 08:00 AM
MarioKart's Avatar
MarioKart
Vendor
Me too
I drilled them out to make a larger hole for the pistion to slide in, but for some reason the bushings still find a way to squeak.
M
Old Oct 26, 2006 | 08:10 AM
FUEGO's Avatar
FUEGO
Are you sure it is the bump stops? Several of the after-market rear swaybars are known to have noisy bushings if not kept lubricated.
Old Oct 26, 2006 | 10:54 AM
meb's Avatar
meb
See, these do exist! Nice kurvhugr!!!
Old Oct 26, 2006 | 12:14 PM
kurvhugr's Avatar
kurvhugr
Yup, that's also where I got springs to retrofit my Megan struts.
I bought two each of the 19-24mm bump stops (so I can decide by direct evaluation rather than someone else's advice) and a pair of Ground Control's spec Eibach springs (slightly barrel shaped) at 375lb.....though I'm still undecided whether I should go with their 440s instead.....
(375lb ~ 6.7kg and 440lb ~ 7.86kg)
Old Oct 26, 2006 | 12:23 PM
obehave's Avatar
obehave
M
Ahhhh! Permanent adjustment
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
Oct 1, 2015 07:05 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
