SS brake lines or Caliper Bushings for better pedal feel?
Old Oct 3, 2006 | 04:08 PM
PenelopeG3's Avatar
PenelopeG3
Trying to figure out whether Braided Steel brake lines or the Caliper bushings will give me better pedal feel. Anyone have any direct experience with this?
I know that on some cars swapping to braided lines doesn't make a difference in brake feel. On other cars its night and day difference.
Are there any legitimate concerns about wear to the solid upgraded Caliper bushings?
This is a street car only. Wife drives it mostly but both of us hate the crappy feel of the stock MCS brakes. Going to be doing pads soon so I figured I'd look into this too.
Thanks.
Old Oct 3, 2006 | 04:13 PM
UKSUV's Avatar
UKSUV
Both will improve pedal "squishiness". Lines more-so than the bushings if you want to pick one or the other.
Old Oct 3, 2006 | 04:59 PM
PenelopeG3's Avatar
PenelopeG3
UKSUV - Which lines and bushings did you use? Thanks.
Old Oct 3, 2006 | 05:13 PM
tsprayfhs's Avatar
tsprayfhs
Shop price, but be sure they are DOT approved. I have used them for years without problems.
Motor on
Old Oct 3, 2006 | 05:25 PM
mini552's Avatar
mini552
I ran this issue by a very honest & qualified vendor, who said that the caliper bushings would give some benefit, but would require more maintenance than most would care to give on a street driven car.
Old Oct 3, 2006 | 05:31 PM
COR BLMY's Avatar
COR BLMY
Both will help feel
I think the line will assist feel more.
Yes the bushings do require more maintance than stock
Old Oct 3, 2006 | 06:14 PM
PenelopeG3's Avatar
PenelopeG3
I guess I'm getting some lines then - probably Goodrich. This and brake pads will be my first "upgrade"
Gonna get the M7 strut reinforcement plates too. Just in case. I remember what used to happen to the strut towers of one the early A1 VWs. I'm getting old....
Old Oct 3, 2006 | 06:17 PM
mbcoops's Avatar
mbcoops
What maintenance do the metal bushings require?
mb
Old Oct 3, 2006 | 06:39 PM
Crashton's Avatar
Crashton
mb
They will need to be lubed at least once a year. Otherwise they will seize up & cause uneven pad wear. It's really not a hardship to lube them. My Miata has the same type of metal bushing. Every spring I give them a lube when I rotate the tires.
Old Oct 3, 2006 | 07:05 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have Goodrich lines on my mini, those along with some Super Blue racing brake fluid really improved feel. My entire brake upgrade also included Hawk ceramic brake pads, and PowerSlot Cryo-Tempered slotted rotors. All in all, braking is better than stock. Brake fade is non-existant, which is why i went with this set up. It took some doing to get them to fade in order to get some pad material on the rotors, but it was worth it.
Old Oct 3, 2006 | 07:18 PM
toddtce's Avatar
toddtce
You might want to look into this:
https://www.northamericanmotoring.co...ad.php?t=77743
I might point out too that there is no such thing as DOT approved hoses as mfg are not required by law to submit hose design for approval. There are DOT compliant hoses (meaning they meet the guidlines of the DOT) and are simply a hose without fittings beyond those required on each end of the hose. Race car hoses with reuseable hoses ends are not "compliant" yet in reality equal to or perferred by many as suitable for use.
Most hoses today (incl those above) use a crimp end on them and the the most common design in use.
Old Oct 3, 2006 | 08:31 PM
limster's Avatar
limster
I had the bushings on my M3 and it did help the pedal feel when the bushings were well lubed. As soon as the lube wore off the pedal feel suffered. I had to lube the bushing at least every 3 -4 months. Most of the BMW people that use the metal bushings are the guys that track their cars and are consistently working on their cars.
Old Oct 4, 2006 | 06:33 AM
UKSUV's Avatar
UKSUV
I'm using Stoptech everything. Bushings are from Moss Mini or Mini Mania...something like that. I can't remember where I got them.
Old Oct 5, 2006 | 02:45 PM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
And remember that upgrading the brake lines will take you out of stock class if you AutoX. I don't know about the bushings though. Unless they pulled the wheels and calipers, they would never see the bushings.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
StealthR53
Aug 8, 2015 10:59 AM
