R52 Squealing tires
Old Sep 10, 2006 | 10:25 AM
chuckyTLC's Avatar
chuckyTLC
Squealing tires
Hi!
Got an '06 cabrio. I'm having more and more "squealing" from my front tires (mostly the driver's one). I used to think it was just my clutchwork, but now I'm getting squealing from that tire when I go around corners. I've checked tire pressure. Anyone else have this problem? Any ideas?
Old Sep 10, 2006 | 03:11 PM
MY4thMINI's Avatar
MY4thMINI
me too
i have about 5000 miles on my tires and i get the squeelz as well...,
i was able to fly around corners for the first few thousand miles and not a peep from the tires,
I just figured it was caused by normal tire wear.
would love to hear the real reason >>
Old Sep 10, 2006 | 06:13 PM
MiniMaybee's Avatar
MiniMaybee
I've got almost 4k on mine and the tires are just now starting to squeal. Almost embarrassing when taking a fast corner with spectators. Must be that the run flats are just now worn enough to loose a little traction and tell about it.
Old Sep 10, 2006 | 08:11 PM
litabelle's Avatar
litabelle
Mine squeal around corners when it never used to. I think I can't wait to swap out run-flats for normal tires.
Old Sep 10, 2006 | 08:30 PM
Motor On's Avatar
Motor On
Are pressures at the right level (i.e. getting all the grip possible?) and have you been really aggressive driving? Which tires are you running I know I reached the point where I need to order winter or all season cause my summers won't hold grip at 60 degrees
Old Sep 10, 2006 | 09:13 PM
pancakex's Avatar
pancakex
Heh. The squeelz, huh? Sounds like a bad disease.
Seriously though.. I have about 1800 miles on mine right now and yeah, the tires are a bit on the squealy side! It was worse when I was just learning to drive stick (ha! ) but now it's better. I wonder if tires would make a difference? If they're still squealing when you need replacements, you can see if the new ones do the same thing.
Old Sep 10, 2006 | 09:26 PM
goldcountrymini's Avatar
goldcountrymini
We don't have squeeling, but peeling out... However, we have LSD on our cabrio.
Old Sep 10, 2006 | 10:38 PM
Motor On's Avatar
Motor On
I dont brake for corners so when its cooler squeals happen
Old Sep 11, 2006 | 05:39 AM
Annewithane's Avatar
Annewithane
Huh. I have 3K on my cabrio and no squeels. Maybe I'm not driving aggressively enough.
Old Sep 11, 2006 | 08:35 AM
chuckyTLC's Avatar
chuckyTLC
Thanks for all the comments and help. To respond, I have the stock 15' wheels and tires, and I don't drive that aggressively. Since it's an '06, I have the traction control (standard). The car has about 4000 miles on it. Tire pressure is good.
Any further thoughts would be appreciated...
C
Old Sep 11, 2006 | 10:37 AM
Nimrod's Avatar
Nimrod
My 05 MCSCa currently has about 17.5K miles on the run-flats. If I get on it hard, I hear a slight squeal too. I do notice that the front tires have much less tread than the rears...never been rotated though.
I'll be replacing the run-flats with regular tires in a few thousand miles too.
Old Sep 12, 2006 | 05:37 AM
ThomB's Avatar
ThomB
I've got 33K on mine and I must be driving "grandpa-ish". My tires don't even squeel when I try. Now If I have my step-son in the car, the DSC goes off and I can get them talking...
Old Sep 13, 2006 | 02:49 PM
justintime's Avatar
justintime
get some r compound tires
Old Oct 23, 2006 | 08:25 AM
Ladybug's Avatar
Ladybug
I would say rotate and re-balance the tires but you have 4000mi. It's almost time to have them done anyways. It really brought the ride back in my car.
Old Oct 23, 2006 | 08:38 AM
mitchman's Avatar
mitchman
Hahahaha. I don't like the squeeling either.
The more tread blocks/siping you have (like on an all-season tire), the more squeeling you'll get. It has something to do with the tread blocks rolling over.....I'm not exactly sure.
A "maximum performance summer tire" with wide tread blocks will not squeel except on rare occasions.
I'm not positive, but I think adding more air will help as well, because it stiffens the sidewalls. Running 2-5 psi more than the factory recommends won't hurt your wear much, give it a try! But first, double check to make sure your pressure hasn't dropped due to the colder weather. (a common problem)
Also, the surface seems to make a difference as well. In my experience, concrete seems to make tires squeel more than asphalt.
I can't wait to get rid of the factory all-season run flats to replace them with Falken RT-615's. I think we're going to buy a second set of wheels and run the factory wheels/tires only in the winter months.
lweaver
Sep 17, 2024 08:22 AM
Casrio
Apr 20, 2021 01:52 AM
dpike
Sep 12, 2015 08:19 AM
Ntety
Sep 2, 2015 08:39 PM
