R50/53 Boot/bonnet warning light won't shut off!
Old Aug 10, 2006 | 08:37 PM
evil_2's Avatar
evil_2
ive already done a search on the forum and read a few posts about the same thing...ive tried some of the ideas with no luck..where is the boot latch sensor at? is my problem more likely to be the boot and not the bonnet?
my MCS is going to the dealer sometime next week to have a scratched window replaced and i might as well have this fixed also but i figured i would give it a shot first
Old Aug 10, 2006 | 08:38 PM
Yucca Patrol's Avatar
Yucca Patrol
it is more likely to be the boot. many of us have had our latches replaced under warranty.
Old Aug 10, 2006 | 08:40 PM
evil_2's Avatar
evil_2
gotta love the warranty!! only problem is my mini dealer is 3 hours away...but i will be using the warranty..oh yes
is there a way i can check the latch switch?
Old Aug 10, 2006 | 08:53 PM
K9MINI's Avatar
K9MINI
My MINI was in and out of the dealership 3 times for this problem. They had to change sensors and harness as well. nothing worse than that warning flashing at ya. Hope they get yours the first time.
Old Aug 10, 2006 | 09:07 PM
evil_2's Avatar
evil_2
yeah i hope so...mine doesnt flash, it just stays on..
Old Aug 10, 2006 | 09:18 PM
SRTech's Avatar
SRTech
You can check the hood switch fairly easily to see if the clip is broken and come loose from the latch assembly. It's on the rear of the passenger side latch assembly and you can see the wire running to the switch attached there. I have seen the retaining tab broken which allows the switch come loose.
Steve
Old Aug 10, 2006 | 09:54 PM
litabelle's Avatar
litabelle
Probably the boot. My husband wedged a little piece of paper in the latch because his was never "closed." The paper has been in for about 3 months, but we'll probably have service look at it next time we go in.
Old Aug 11, 2006 | 06:59 AM
evil_2's Avatar
evil_2
well guys i made my appointment with the dealer to replace my scratched window and to fix my boot/bonnet warning light..i just wish the dealer wasnt 3 hours away..
Old Aug 11, 2006 | 09:28 AM
Mrs. Skurvy's Avatar
Mrs. Skurvy
I had the same problem earlier this week. For some reason I decided to put my key in the door lock and turn it to the right to lock it and after that all has been fine and dandy.
Old Sep 14, 2008 | 09:37 AM
wmdapple's Avatar
wmdapple
same issue.. sort of
2002 MCS
the warning light won;t go off. Took the switch out of the trunk latch assembly. It works fine.. Put it back in and it did as before,., Trunk light off (as is Dome) but the warning light is still on. Wondering if there is a relay problem or just a in the warning light. I would think that the trunk latch switch woud be the switch for both the trunk and and the warning light.. Is there more than on element there?
any help appreciated.
WM
Seattle
bneer
Jul 15, 2019 04:41 PM
Lschneider
Aug 21, 2015 02:21 AM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
