Suspension 05+ w/ Fixed Ireland Engineering Camber Plates + Lowered
Old Jun 12, 2006 | 01:46 PM
matma92ser's Avatar
matma92ser
Apparently the 05-06 Minis have a slight interference problem in the front that prevents camber from getting more negative than approximately 1.2 degrees or so. There are reinforcing "ribs" in the sheet metal of the drivers side strut tower that will contact the spring at the end of the camber adjustment.
IE sells fixed camber plates that will give you -1.25 degrees on top of stock. If your car is lowered, the final camber setting will probably be anywhere from -1.5 to -2.0 degrees.
Has anyone with a lowered 05-06 Mini tried these plates? Can you confirm if this interference problem is an issue?
Old Jun 12, 2006 | 03:49 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
See the post below this one. There is a potential for interference, but a few well placed hammer blows seems to fix the problem for good...
cheers!
Old Jun 13, 2006 | 06:33 AM
oldschool's Avatar
oldschool
I'm using the fixed plates but with KW coilovers ... no problems.
-2.0 in front.
W0TM8
Dec 19, 2019 07:50 AM
sabjcw
Aug 14, 2015 07:40 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
