Sun Roof Drain Tube
Old Jun 5, 2006 | 08:23 PM
Motorrr's Avatar
Motorrr
Sun Roof Drain Tube
In an attempt to imitate Sherlock Holmes and find the cause/source of water leaking into the driver-side floor board area, where does the sunroof drain tube terminate? Under the car,behind the firewall? In the engine compartment? Where? Is this tubing ridgid, i.e. copper or aluminum tubing? or flexible rubber or poly' tubing? Where is it supposed to exit the vehicle? HELP.....
Old Jun 5, 2006 | 08:28 PM
SB's Avatar
SB
If I recall correctly, from my last MINI with a sunroof. There are two tubes that exit the body near the roof in the boot.
Old Jun 5, 2006 | 09:22 PM
ofioliti's Avatar
ofioliti
That is correct. Open the boot and you will see two holes lined with rubber near the roof on either side. The tube can be seen here:
http://www.realoem.com/bmw/showparts...90&hg=54&fg=05
Old Jun 6, 2006 | 08:43 PM
Motorrr's Avatar
Motorrr
Ofioliti,
Thank you for the info. I'll check to see if these are plugged. Their has got to be a simple explanation to my water leak issue. I hope this is it.
Small world....I see you live in Kirkwood, Mo. I lived there from 1950 to 1965. Terrific town and a great place to grow up. Thanks again, Bruce
Old Jun 6, 2006 | 09:34 PM
ofioliti's Avatar
ofioliti
Originally Posted by Motorrr
....I see you live in Kirkwood, Mo. I lived there from 1950 to 1965. Terrific town and a great place to grow up...
... and it still is!
Good luck with you're search. Let us know if you solve the mystery!
Old Jun 6, 2006 | 10:52 PM
caminifan's Avatar
caminifan
Ofioliti,
Another item that could be causing water leaking is that the drain tubes are pressed shut. Depending on how the installation was done at the factory, there could be a piece of trim pressing the tube(s) shut (the trim presses against the drain tube and closes it shut). You may have to follow the tubes from the boot drain point back to the sunroof (on both sides). The unfortunate thing is that if you have a drain tube that is pressed shut by a piece of trim, the tube seems to have a memory (of being shut) and then must be replaced. If this is the circumstance, I hope the car is still under warranty.
Old Dec 11, 2006 | 01:40 PM
mgf1970's Avatar
mgf1970
Here's a pic I posted in another thread that might be helpful. My father's 2003 MCS and my 2002 MC had the exact same problem. https://www.northamericanmotoring.co...3&postcount=12
Old Dec 12, 2006 | 06:28 PM
Motorrr's Avatar
Motorrr
mgf1970, I can see where the two hoses should connect. I'm not certain of the location of the two hoses relative to the headliner/front of the car. Looking at this view...Is the camera facing forward?
Perhaps this maybe the culprit. Thanks for your time and photos
MOTORRR
minimofo
Sep 30, 2015 12:26 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
Sep 4, 2015 09:10 AM
schwac2
Sep 3, 2015 08:56 PM
Sep 2, 2015 09:05 AM
