SS Brake Line Tutorial
Old May 31, 2006 | 02:17 AM
MGear's Avatar
MGear
I am going to have stainless steel brake lines installed but before I go to my local Mini dealer and wacked I thought I would ask if anyone has posted a good tutorial on bleeding the brake system, removing the stock lines, installing the new SS lines and replacing the brake fluid. I am not a mechanic and have never done any brake work except to change pads and brake bushings along with other similar type mods throughout the car. I noticed the post section on brakes has over 133 pages and the search engine on NAM doesn't work that well so if anyone can remember a good thread/tutorial on the subject please point the way and thanks alot!
Old May 31, 2006 | 07:20 AM
polmear's Avatar
polmear
Here :
https://www.northamericanmotoring.co...ace+brake+pads
and here:
OctaneGuy didi a couple of nice write-ups with pics and all
Old May 31, 2006 | 07:29 AM
Dr Obnxs's Avatar
Dr Obnxs
Some key things to remember....
it's no big deal, but make sure the resivoir doesn't go dry....
And clean off any leaked brake fluid right away. This isn't a hard job... but it is a bit messier because you open the lines.
Also, I've found that I needed to bleed the brakes more than once. I'd bleed, then go drive for a bit (seemed to knock off little bubbles from inside the caliper) and then go bleed again to get the last air out. Nothing hard, but don't be surprised if you need to do the same thing...
Matt
Old May 31, 2006 | 08:52 AM
toddtce's Avatar
toddtce
Best fluid for cleaning off the brake fluid on the caliper or fittings: Water.
Old May 31, 2006 | 12:42 PM
MGear's Avatar
MGear
Thanks guys for the info I will follow up based on your feedback!
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
