Will it rub thread?? : 215/45/17 +45et -17"x7"
Old May 17, 2006 | 01:53 PM
defylogik's Avatar
defylogik
Ok, i have searched and searched, but i have not found the exact answer that i seek.
does anyone have this combo:
and does it rub?
the tires are geforce KDW (tread pattern 1 - less aggressive looking)
basically that combo, will it rub. the offset is 45et. i see a lot of posts with people below 40et and rubbing but no one with this higher (tighter) offset?
thanks for the help!
scott
Old May 17, 2006 | 01:56 PM
MSFITOY's Avatar
MSFITOY
and does it rub?
scott
215/40-17 +40 didn't rub...215/45-17 +45 doesn't rub...of course, my rear camber is at 1.6 which helps...
Old May 17, 2006 | 02:10 PM
kyriian's Avatar
kyriian
215/45-17 +45 will not rub even with 1.2 rear lowering...
although same tire size at +40 will rub.... (i know first hand!) max ive went with 215/45-17 would be +42
Old May 17, 2006 | 02:55 PM
defylogik's Avatar
defylogik
cool, so no rubbing. that is good. i may throw on some h-sport springs for a while and blow my stock struts out ... or coil overs i cannot decide.. so much $$$..
msfittoy - btw i have the exact same car as you. i am soon going to be your clone!!! (soon as i get a light bar) beware!
Old May 17, 2006 | 03:03 PM
Lexster05's Avatar
Lexster05
I have 225/45/17 tires...no rubbing (only when I hit dips at speed).
Old May 17, 2006 | 04:11 PM
Jenn B's Avatar
Jenn B
I have that exact setup and I get barely any rubbing. As stated above, only on large bumps, at speed, which I try not to do but have had 2 or 3 times that they snuck up on me. But day to day, normal conditions... none.
Old May 17, 2006 | 09:40 PM
defylogik's Avatar
defylogik
this car sees track and auto-x time also. any concerns?
scott
Old May 22, 2006 | 07:01 AM
defylogik's Avatar
defylogik
let me clarify though, i have these tires on the car with stock suspension and i have no rubbing. i am meaning if *lowered*, is there any rubbing??
probably 1-1.5" lowered when all is said and done.
thanks
elverado
Jan 18, 2022 02:51 AM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
Carwash
Sep 15, 2015 02:02 AM
makg
Sep 10, 2015 11:59 AM
