Rotor removal
Old May 16, 2006 | 09:34 AM
ProfessorDave's Avatar
ProfessorDave
Rotor removal
Hi all,
Is there any trick to removing the brake rotors? I am anticipating the need for some persuation with a rubber mallet or dead blow hammer, but want to be prepared before I start my pad/rotor replacement project.
Thanks!
Dave
Old May 16, 2006 | 09:40 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Just remove the torx head screw holding it on and it should come right off.
Old May 16, 2006 | 09:44 AM
Dr Obnxs's Avatar
Dr Obnxs
Get the torx bit before you start.
otherwise it's a dead end.....
And some persuation may be needed.
Matt
Old May 16, 2006 | 09:45 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Generally all you need is the soft mallet to knock the inevitably rust-stuck rotor from the hub in addition to the Torx bit needed to remove the single rotor retaining screw.
In addition to removing the calipers, on the front you will need to remove the caliper adaptors to gain clearance to remove the rotors. In fact, you need only remove the lower bolt, loosen the upper and swing the adaptor up to get the rotor off the hub.
Remember, you will need a caliper piston retracting tool if you are replacing the rear rotors and/or pads. A simple c-clamp works for the front.
Old May 16, 2006 | 09:47 AM
techno99's Avatar
techno99
I usually leave one or two of the wheel bolts on loosely so the rotor doesn't hit your foot when it all of a sudden falls off. Sometimes the hardest part is getting the screw out. Also, don't forget to release the parking brake when doing the rears.
Old May 16, 2006 | 09:52 AM
dominicminicoopers's Avatar
dominicminicoopers
Be sure not to strip the head of the torx screw. I did on mine and it was a pain getting it out. Use something like PowerBlaster or WD40 on the screw and let it soak in before attempting to remove...it should make it easier. Push in with the torx bit while trying to unscrew it, otherwise the torx bit will walk its way out of the recesses and mar the screw.
Old May 16, 2006 | 12:26 PM
ProfessorDave
Is the torx a special size? I have the usual homeowners set (which is, er, at home so I can't check the size range right now), but in the picture Partsman109 supplied it looks like it might be a larger size.
Great advice from everyone by the way...Thanks!
Old May 16, 2006 | 12:29 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I think it's a T45 or T50.
An impact driver works good for this screw.
Old Jun 13, 2006 | 06:33 AM
mmatarella's Avatar
mmatarella
T50...
Felt with a T45 last night and it was a little loose. T50 was perfect, on my '05
Old Jun 26, 2008 | 01:45 PM
Gil-galad's Avatar
Gil-galad
I'm glad my search found this thread. For some reason the Bentley Manual doesn't provide a clue as to the bit size needed for the rotor Torx -- just gives the torque recommendation.
T50 purchased. Calamity avoided.
Old Jun 26, 2008 | 05:08 PM
wellzy's Avatar
wellzy
Originally Posted by ProfessorDave
Hi all,
Thanks!
Dave
first get a tork driver like the doc said. next get a big hammer (not rubber) and a 1/2 inch rod (half inch driver extintion will work). place 1/2 rod on top of flat head tork screw and smack it hard with the hammer. this will help you get it out.
Old Jun 26, 2008 | 05:17 PM
Crashton's Avatar
Crashton
I've used an impact driver to good effect. Also before putting the torx back in give it a kiss with some anti-seize. That will make things much easier the next time you have to remove it.
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
greekzilla
Aug 23, 2015 03:44 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
