CAI Intake noise question...
Old May 8, 2006 | 08:18 AM
hopper's Avatar
hopper
I've been running a Helix CAI for a few weeks now and have generally gotten used to the intake noise..... BUT there is another whine, actually more like a whistle (from a vacuum line?) that comes on only under very light or feathered throttle. It's annoying on the highway. Can anyone shed any light or offer a suggestion?
Thanks,
hopper
Old May 8, 2006 | 08:20 AM
mdsbrain's Avatar
mdsbrain
Normal noise. Usually heard when making a small correction of speed on the highway. Super annoying to some.
Old May 8, 2006 | 08:25 AM
qwertmonkey's Avatar
qwertmonkey
I had the same thing. Its the vacuume line. Well, I have a MCSa so i have 2 vacuume lines. I have an HAI so i put a "mini" filter on them. It works.
Old May 8, 2006 | 10:00 AM
hopper's Avatar
hopper
Where are the lines located? Is there a downside to puting a "mini filter" on them?
tia
Old May 8, 2006 | 10:03 AM
Motor On's Avatar
Motor On
The wistle is air passing over the TB, it wont completely go away but should quiet itself down quite a bit after a few hundred miles from clean, all depends on what kind of air you drive through really. No worries its all normal.
Old May 8, 2006 | 11:05 AM
hopper's Avatar
hopper
It's got the better part of a thousand miles on it now with no change in the whistle at a slightly cracked throttle. Open the throttle further and the whistle goes away almost immediately and is then replaced by sc whine. I'm thinking that it might have something to do with the bypass valve.
Old May 8, 2006 | 11:11 AM
mdsbrain's Avatar
mdsbrain
Did you install the intake with or without the plastic partion behind it? With it in the noise should be a bit less.
Old May 8, 2006 | 11:21 AM
qwertmonkey
The vacuume line(s) are on the stock intake tube from the airbox to the TB.
Colt45Magnus
Aug 27, 2024 05:03 AM
tr3y003
33
Jun 5, 2020 05:00 AM
rtk90
Aug 29, 2019 09:08 AM
MasterShaftner
Sep 4, 2015 03:52 PM
David.R53
Sep 1, 2015 06:49 PM
