Chirping sound at take off
Old May 5, 2006 | 12:16 PM
kliebss's Avatar
kliebss
I recently started to hear a little chirping noise coming from the front of my MCS. it is only for a split second then it goes away. it almost sounds like a little beeping horn. this occurs when i accelerate from a stop. im thinking it is a problem with the transaxel oil or something along those lines. Can i somebody please give me some input?
Old May 5, 2006 | 12:24 PM
chows4us's Avatar
chows4us
Sound like your lighting up the front tires before the DSC kicks in
Old May 5, 2006 | 12:33 PM
XAlfa's Avatar
XAlfa
Learn to love it.
Old May 5, 2006 | 12:35 PM
Motor On's Avatar
Motor On
Originally Posted by XAlfa
Learn to love it.
OR ease off the gas, have you checked front tread wear recently?
Old May 5, 2006 | 12:47 PM
Rossii's Avatar
Rossii
Check the belt on the pulley for play......it might be slipping.
Old May 5, 2006 | 02:05 PM
pooch1's Avatar
pooch1
Hope its not the dreaded "OOORT" sound,if it is its the clutch/flywheel issue.See under search "clutch squeal".Good luck
Old May 5, 2006 | 04:05 PM
coopercrazy's Avatar
coopercrazy
I get it too.
Plus i sometimes get a click when i release the clutch in 1st.
Old May 6, 2006 | 07:37 AM
DownSize's Avatar
DownSize
my shocks make a chirp everytime I go over a bump. is that it?
Old May 10, 2006 | 12:19 AM
Crow's Avatar
Crow
I recently started to hear a little chirping noise...
I know exactly what you are talking about. It's a little click noise that happens as you pass a certain low speed in first gear while starting out. I asked my dealer about after I first got my MCS (mine's an '03) and he said not to worry and that all the cars have it. He did tell me what it was but I can't remember now... something engaging... I do remember being satisfied with the explanation, which is why I probably forget what it is now.
Old May 10, 2006 | 07:36 AM
XAlfa's Avatar
XAlfa
Originally Posted by Crow
... something engaging....
...something charming...something wonderful....
(It's the clutch.)
Old May 10, 2006 | 07:42 AM
shankrabbit's Avatar
shankrabbit
If it is the clutch, does the dealer usually do something about it under warranty?
I like to describe the noise like that of a mating pigeon, as if it were under the front of my car trying to get laid by my clutch.
Old May 10, 2006 | 01:41 PM
beken's Avatar
beken
I've mentioned it happening to my MINI Service and he said they would log it down and just watch it. This happens intermitently and he's hoping he doesn't put in a new clutch and find out the problem he thinks it is, isn't the problem.
Anyways, if my clutch breaks over this, it's covered under warranty.
I would advise you let your MINI mechanic know and have it logged down that it's happening.
The clicking noise some of you have mentioned just as you start out (at about 5mph) was explained to me by the mechanic as the ABS self check.
Old Jun 28, 2006 | 02:03 PM
Crow's Avatar
Crow
(It's the clutch.)
That's hilarious. But this is long after the clutch is fully engaged.
Old Jul 14, 2006 | 02:26 PM
lcubed's Avatar
lcubed
just got back from getting my 05 MCS serviced up at mini of towson.
while i wandering around the sales lot, i encountered
the tech who was moving my vehicle over to service.
i flagged him down when i heard the chirping noise as he
was engaging the clutch into reverse. it was quite loud
when heard from outside the passenger compartment.
the tech identified the noise right on the spot.
they replaced the left front axle assembly.
the metallic chirping noise is gone!!
Old Jul 28, 2006 | 10:47 AM
Zarrik's Avatar
Zarrik
Good to know. I have this exact same issue with my Mini. You hear it when reversing from a dead stop and occassionally when accelerating. Every now and then, it'll chirp repeatedly when cornering.
I'm bringing it in to the dealership next Saturday, so I'll ask them to look at the axle assembly. Thanks for the heads up!
Colt45Magnus
Aug 27, 2024 05:03 AM
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
atlantaorange
21
Oct 2, 2015 12:32 PM
Joeygonz
Oct 2, 2015 11:24 AM
