window problems
Old Apr 30, 2006 | 04:17 PM
sdv515's Avatar
sdv515
window problems
when i got in my car this morning i was unable to open the driver side window. everything opened up and i could hear it trying to move but it didnt. but when i got back in about 6 hours later the window worked fine. made me feel wierd opening the door and asking for a coffee at tim ho's. wondering what i should do
Old Apr 30, 2006 | 05:15 PM
Alerious's Avatar
Alerious
This is a common problem with MINIs, one that I've had to deal with myself on a number of occassions. I forget how long, but if you hold up the window button for the offending window for a period of 15 seconds or so, the computer will reset and the window should work just fine. If I recall correctly, it had to deal with some sensor that detects whether the window is fully up or not, so holding the window button up causes the computer to reset and read the sensor position of the window again. If you want more info, though, I'd search for some past threads dealing with this issue, as it's been covered numerous times here before.
Old Apr 30, 2006 | 05:37 PM
sdv515's Avatar
sdv515
thanks i will try have to try that next time.
Old May 2, 2006 | 11:33 AM
joedude99's Avatar
joedude99
Had Windows Serviced
Just had the switches and motors replaced in both windows. I felt very "ghetto" having to get out of the car while paying tolls.
Old May 2, 2006 | 01:24 PM
myzamboni's Avatar
myzamboni
If the window is stuck, hold the window switch down and bang against the door panel just above the speaker. This usually jars it loose. I have had a window stick twice in 2 years of ownership. This trick solved the issue both times.
Old May 2, 2006 | 04:44 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Now that's a "ghetto solution"
Old May 3, 2006 | 11:26 AM
qwertmonkey's Avatar
qwertmonkey
Ditto!!! ^ ^ LOL!
Door and window problems seem to be fairly often in the later MINIs. I havent had any trouble yet, but I dont want to jinks it! Yikes!
Old May 3, 2006 | 03:12 PM
dukesantos's Avatar
dukesantos
Just had my passenger window repaired, it wouldn't go up or down. Dealer said it was the "cable", they fixed it quickly under warranty.
Old May 3, 2006 | 03:15 PM
myzamboni's Avatar
myzamboni
May be "ghetto", but do a search on here for stuck window and you will see many have done this. Also, some MINI service techs have even suggested this. If you really need the window open, you have an ace up your sleeve.
Old May 3, 2006 | 03:28 PM
pcnorton's Avatar
pcnorton
Its starting to happen to me again. Only when it very hot inside the car.
Paul
Old May 3, 2006 | 07:36 PM
sdv515's Avatar
sdv515
it is working reliably now and i now longer have to squeeze out of the door at the drive thru. i didnt want to go around hitting things until i knew i wasnt going to break anything expensive
Old May 3, 2006 | 08:09 PM
89AKurt's Avatar
89AKurt
My right window stopped going down. I helped it along, now window works, but the door lock is acting stupid now.
Old May 9, 2006 | 01:03 PM
LRogers's Avatar
LRogers
I had a problem with intermittant functions, it finally reached a point of not working at all. My dealer (Ralph Schomp) in Denver replaced the non working parts under warranty. LRogers
Old May 27, 2006 | 09:36 PM
Red's Avatar
Red
03 MCS Drivers door grinding solved with regulator and motor at 6k Passenger side intermittent problem now is solved. It's a permanent problem now at 16k
Maybe the dealer can fix my fuel gauge while I am there. I wonder if I checked off the Lucas electronics option by mistake?
woodstudio
Mar 15, 2020 08:28 AM
cawwwtun
May 3, 2016 08:03 AM
Dec 23, 2015 10:36 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
