Navigation & Audio MINI iPod Adapter and the AUX input
Old Mar 23, 2006 | 11:18 AM
dickdavid's Avatar
dickdavid
Can I have both on my 06 MC with HK? Right now, I have the iPod adapter but would like to have the AUX port as well.
I've searched the archive, but didn't come up with a definitive answer. Can somebody help with this mystery?
Old Mar 23, 2006 | 01:58 PM
aDeLoreanGuy's Avatar
aDeLoreanGuy
Yes, you can have both. The Aux imput uses a dedicated port on the back of the HU.
Old Mar 23, 2006 | 02:34 PM
dickdavid's Avatar
dickdavid
Thanks!!
Old Mar 25, 2006 | 06:48 AM
mini552's Avatar
mini552
OK now I'm confused - been reading up on the various Ipod hookups . . .
I thought the factory adapter did include a connector to the rear of the stereo head unit - i.e. just like the aux input cable but including hideaway cradle, charging capability, etc.????
Old Mar 25, 2006 | 08:20 AM
dickdavid's Avatar
dickdavid
I know that both have connectors to the back of the head unit. I just wasn't sure if they shared the same port. Looks like they don't.
Old Mar 25, 2006 | 09:18 AM
dukiebluedoc's Avatar
dukiebluedoc
Hope I'm not hijacking this thread but my MA (Mike Snyder at Classic Mini)
emailed me that I could NOT have both an AUX input and the OEM iPod adapter on my '06 MCSC with H/K
would someone know of a definitive source to which I can refer him--I think the installation is happening this week.
thanks
Caroline
Old Mar 25, 2006 | 09:33 AM
rkw's Avatar
rkw
The iPod adapter uses the connections that were originally intended for the CD changer. They are separate from the aux input.
Here's someone who has both: https://www.northamericanmotoring.co...ad.php?t=63421
Old Mar 25, 2006 | 03:37 PM
dukiebluedoc
gracias RKW
I just got an email from my MA apologizing for the wrong info--he will make sure both inputs are installed on my Mini next week
Old Mar 25, 2006 | 06:00 PM
o-ron's Avatar
o-ron
FWIW..
I found this little guy a while back at circuit city:
http://catalog.belkin.com/IWCatProdu...duct_Id=149006
This provides power to charge your ipod through the dock connector, *and* provides a dedicated, adjustable preamp built in with 1/8" line out connector. In the case of the MINI, just run a 1/8" stereo jack from the belking unit to the aux in, and then simply plug your ipod into the dock connector whenever you want to use it.
The advtanges are that it's only 1 cable to plug into the ipod, you get cleaner sound (by using a dedicated preamp instead of the headphone plug on your ipod), and accidentally bumping the clickwheel doesn't cause the volume to explode over you speakers! (volume is controlled from the MINI head unit).
Anyway, it's $40 and has worked well for me.
Otherwise, look into the Ice Link adapter, as the OEM ipod dock is pretty useless...
http://www.motoringfile.com/2005/04/..._plus_reviewed
Old Mar 25, 2006 | 06:46 PM
dickdavid's Avatar
dickdavid
I had the Belkin Auto Kit in my last MINI. I highly recommend it for those with the AUX input.
I got the MINI iPod adaptor this time which is nice, too. It was a little limiting at first, but now I'm comfortable with the interface.
I want the AUX input as well, just in case I want to plug in something other than an iPod.
Old Mar 25, 2006 | 08:45 PM
rkw's Avatar
rkw
I want to mention that when powering the iPod from the cigarette lighter, some people have problems with the aux input randomly disconnecting. If this happens, it is caused by electrical noise, and you should add a "ground loop isolator" from Radio Shack or some other source. Search the forums for ground loop isolator, and you will find many references.
eliseo1981
Jan 28, 2021 02:45 PM
penguinhomey
38
Jul 7, 2019 09:24 PM
ludedude
Aug 10, 2015 07:16 PM
tippin
Aug 5, 2015 08:43 AM
