R52 cleaning inside rear window
Old Mar 2, 2006 | 06:38 PM
frank miller's Avatar
frank miller
I am a smoker and am trying to figure out how to access the inside rear window on the ragtop to clean it.
Old Mar 2, 2006 | 06:50 PM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
I have the same issue and there is no easy way. I just crawl in the back seat on my knees and do the best I can...
Donna
Old Mar 2, 2006 | 07:31 PM
Newdl's Avatar
Newdl
I know this is a different car....and I only have had 1 days worth experience with a mini conv. but....on my moms bmw 3series there is a position when the top is going up or down when you can stop the motion(releasing the button) and clean the window.....if this does not work...what about the hinge (the one that helps fit larger items into the trunk)....can you open that and reach?
Old Mar 3, 2006 | 04:26 AM
Rev. Limiter's Avatar
Rev. Limiter
Open the boot.
Release the two locks and raise the window - rotate one of the locks back to its resting place.
Remove the cargo cover.
Spray the inside of the window with "Invisable Glass".
Wad a newspaper sheet and wipe vigerously (sp?) across the glass.
Throw the newspaper to the ground.
Wad another newspaper sheet and "polish" the glass.
Pick up the newspaper, throw in nearest trash can, reinstall cargo cover, lock glass, and close boot.
Go in the house and wash newsprint from hands.
You will be amazed how clean the glass is!
Old Mar 3, 2006 | 04:31 AM
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
Add so vinegar to the equation and you will get cleaner glass, as the vinegar cuts through all grime. newspaper real good to use....
Old Mar 3, 2006 | 04:33 AM
snooter's Avatar
snooter
Mr. MOTD
Quit Smoking?
Old Mar 3, 2006 | 05:00 AM
ThomB's Avatar
ThomB
Donna
This is a family board so I'm not posting what came to my mind...
Old Mar 3, 2006 | 07:49 AM
alpinamike's Avatar
alpinamike
The opeing of the rear lid does work the best, dont try to get it from the inside.
-alpinamike
Old Mar 3, 2006 | 08:24 AM
Porco Rosso's Avatar
Porco Rosso
You might get more room to maneuever if you fold down the rear seats.
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
bugeye1031
Aug 15, 2015 08:14 AM
