R50/53 Brake Light Mod Warranty Issue!
Old Feb 15, 2006 | 02:42 PM
kristina's Avatar
kristina
Hi all. I have a 2004 MC, in which I had the brake light mod installed when I picked up the car almost two years ago. The other day, I had major electrical problems with the car. The dealer has told me that the problem was caused by the mod and that nothing will be covered under warranty. The damage is $1300.
First, has this happened to anyone else; and second, do I have any recourse or am I totally screwed?
Old Feb 15, 2006 | 02:48 PM
umberto's Avatar
umberto
HOLY COW!!!
It is hard to imagine that really being the culprit as the amperage drawn by those two extra brake lights is really pretty minimal
Old Feb 15, 2006 | 02:51 PM
planeguy's Avatar
planeguy
Unfortunately you are probably screwed. You may get someone telling you about the Magnasson-Moss act but unless you spend thousands in legal fees to go to court and get it decided in your favor....you're screwed.....Im sorry to hear about your troubles.
Now when you say "installed when I picked up the car" does that mean that the dealer installed this mod for you?
Old Feb 15, 2006 | 02:55 PM
pcnorton's Avatar
pcnorton
Need More info:
What was the problem. What are the major electrical problems? Engine or body work? What needed to be fixed? If it was the wiring in the rear tail lights melted then I would say you are definately screwed.
The squeaky wheel gets the grease so I wouldn't just roll over.
But befor anyone give's their .02 to be accurate we need alot more info.
Paul
Old Feb 15, 2006 | 02:58 PM
kristina's Avatar
kristina
The module that controls all the electrical stuff (lights, windows, locks, etc.) has to be replaced. I"m sorry, I forget what it's called. I was given no other information other than that the tech is sure that the modification to the tail lights caused the problems.
Old Feb 15, 2006 | 02:59 PM
hyobum's Avatar
hyobum
Ask them to prove it?
fake edit: The brake light mod could be the culprit, because the REAR fog lights, which is converted to an extra brakelight, work with the toggles.
Old Feb 15, 2006 | 03:10 PM
TWISTER's Avatar
TWISTER
This seems so out of place on this mod. I'd like to learn more about your issue
Old Feb 15, 2006 | 03:11 PM
jonnieoh's Avatar
jonnieoh
I'm not an electrician, so forgive my naiveté, but how could the extra brakelight mod POSSIBLY affect any part of the car, except perhaps the tail lamps????
Could somebody with technical expertise please explain this, in layman's terms?
I ask, because I too, have the extra brakelight modification, so I am obviously concerned now...
chrisneal's Avatar
chrisneal
How many other hundreds of people have done this mod with no problems?! That's ridiculous - there has to be some way to decide this between "the tech said ____" and getting expensive lawyers involved. I would do a bunch of reading up on how this sytem works in the MINI - if you demonstrate a bit of knowledge, maybe they'll back off of their claim. Arm yourself with figures on the amperes, resistance, etc. involved. I'm sure people here (but not me) can help in this regard. Good luck!
Old Feb 15, 2006 | 03:23 PM
MNEEME's Avatar
MNEEME
I say contact "Greatbear" I'm sure he'll be able to shed some light on this issue!
Here's his profile on NAM:
https://www.northamericanmotoring.co...ber.php?u=6470
CALLING GREATBEAR, CALLING GREATBEAR!
Old Feb 15, 2006 | 03:35 PM
planeguy's Avatar
planeguy
Stick a paperclip in the light socket and let me know if your breaker flips or your house burns down
The earliest breaklight mods I recall was just exactlly that! The mod is basically a jumper in the circuit.
I agree that the mod has been done literally thousands of times without problem BUT the potential for frying your ECU is certainly there!
Old Feb 15, 2006 | 03:37 PM
planeguy's Avatar
planeguy
Originally Posted by Agro
Mr Bridger, yes. It's a simple mod. Remove the access panel in the boot. Reach in and unclip the light assembly. It's a circuit board with 3 lights on the outside side. Using a piece of wire, a diode or even a paperclip, short wires 1 and 4. Re-install the board, making sure to have the wiring harness BEHIND the board (towards the front of the car). replace the access panel. Repeat for the other side.
https://www.northamericanmotoring.co...reply&p=542855
For a more detailed look
http://www.littlemini.us/technical/brakemod/index.asp
Old Feb 15, 2006 | 03:40 PM
MNEEME's Avatar
MNEEME
Sorry for running off topic but I had too!
Edit:
In case you haven't seen that before its from a video of a guy playing a joke on his friend (guy on the right) Guy on the left is fixing a switch and pretends to be electrocuted. Friend flips out and throws the Banana at him!
LINK TO VIDEO: http://www.youtube.com/?v=e28YeSHkhn8
Old Feb 15, 2006 | 03:47 PM
Dr Obnxs's Avatar
Dr Obnxs
Isn't this what fuses are for?
Really, if the control unit (it's not the ECU, it's one of the body control modules behind one of the kick panels), it should be able to handle this mod without frying. The problem you have run into is they already know that you had the mod.
There are some specs that come into play. That is the current draw of both set ups, and the output current rating of the unit. Ask them to show you that the unit isn't rated for the load of the mod. But I fear you're screwed.
If you'd yanked the mod before going in, they'd be eating the part.
Also, use one of the used part locating services on the web. I bet you can get the module from a wrecking yard for $200 or so. You may have to get your set of features enabled at a dealer, but I think you can save a ton of money if you search for a used part.
Afterall, there are lots of Mini's that have been overdriven and kissed a tree or equivalent...
Matt
Old Feb 15, 2006 | 04:16 PM
JRZYMINI's Avatar
JRZYMINI
I imagine how mod's affect your warranty are at the discression of the dealer... maybe you can find a different dealer for a second opinion?
Old Feb 15, 2006 | 04:31 PM
SonicVI's Avatar
SonicVI
It's not the same thing. You're connecting the hot wire to ground with the paperclip in lightsocket, which effectively elimates the resistance from the circuit and allows the current to rise until it reaches the fuse or breaker's limit and blows it. You won't burn your house down unless maybe you already have faulty wiring or an underrated fuse/breaker. This mod is jumpering a hot wire to another hot wire, which runs the two bulbs in parallel.
Old Feb 15, 2006 | 04:36 PM
not-so-rednwhitecooper
I had a BC1 problem with my car before, not due to the brakelight mod, but they said my LED brake lights messed up the BC1 and the brake pedal switch (yeah, right)
if the idiot would have told me it was just a $25 dollar switch, it would have saved me the $400 install cost.
Yet another reason i'll NEVER go back to Classic BMW/MINI's service bay for work!!!!
Old Feb 15, 2006 | 04:41 PM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
As Chris metioned above, I think it would certainly behoove you to do some reading - also including the Magnuson Moss Act. I am not a lawyer, nor have I had to wrangle with this issue before, but I believe that they need show verifiable PROOF that it was the mod that caused the failure. Just telling you they believe it was the problem - no matter how convicingly - isn't proof.
...Of course, it all depends how much $1,300 means to you. It would mean at least a few hours of reading and research if it were me.
Good luck!
Old Feb 15, 2006 | 05:04 PM
Dr Obnxs's Avatar
Dr Obnxs
That's not the law...
But then the dealers apear to not know the law either!
Matt
Old Feb 15, 2006 | 05:11 PM
SB's Avatar
SB
If I'm not mistaken. On cars without the optional fog light enabled, there was no worry to supply power to this wire as it basically is not going to affect anything at the other end. I doubt if the doubling of the bulbs caused a problem as the fuse should have blown if there was an issue. The only thing I can think is if something in the switch panel shorted and caused problems with the DME.
MINI techs are the worst people I know for inventing excuses too either get you to leave with the problem or get money out of you.
What concerns did you have that made you take your MINI in?
Old Feb 15, 2006 | 05:30 PM
kenchan's Avatar
kenchan
kristina -which dealer and who was the tech that told you?
Old Feb 15, 2006 | 06:02 PM
kristina's Avatar
kristina
This is Mini of San Francisco. What happened is that I parked the car in the garage and noticed that one of the rear tail lights was still illuminated even after the engine was off, key was out, etc. Some hours later, the front light (the one below the headlight) was also illuminated. Since this was late at night on a weekend, I couldn't do anything about it. By the next day, the battery had run down.
Right before this happened, I had the hazards on for about 10 minutes. Could this have caused a short and the ensuing frying of the BC1?
Old Feb 15, 2006 | 06:07 PM
MNEEME's Avatar
MNEEME
As for the lights being on thats a feature in the MINI. If you push the turn signal down for the left and up for the right the parking lights come on and will stay on. And this is only on one side. Works without the engine on, key out, etc. I do know that.
Old Feb 15, 2006 | 06:28 PM
rkw's Avatar
rkw
This same topic has come up before: https://www.northamericanmotoring.co...d.php?p=639507. In that case, the poster did manage to get it covered under warranty. However, at that time our electronics guru GBMINI (Ian Cull, inventor of the auto-up circuit) had this to say:
Originally Posted by GBMINI
I think you are very lucky. If I was the tech, I probably would have stuck with the no-warranty issue.
The fact is that yes many MINIs have this brake light / rear fog mod.
BUT what the mod actually does is to double the load on the brake light circuits coming out of the BC1.
The BC1 is designed to drive 2 x 21W bulbs (one each side), and the center brake light. The mod connects a second 21W bulb to each side.
Obviously this mod increases the load on the BC1 beyond that which it was designed. We can say it should survive a short-circuit, but a doubled load is not the same as a short and actually could do more harm than a true short (because the true short will be detected and protected from, while the overload will leave the BC1 trying to work normally).
So to my mind, if you do the mod and the BC1 fails, it is caused by your mod which you chose to do, and you should expect no warranty.
PS: Lucky for you I am not a MINI tech
If you have electrical problems, it would be advisable to remove the mod before going to the dealer!
Old Feb 15, 2006 | 06:41 PM
Rich.Wolfson's Avatar
Rich.Wolfson
I have a 2003 and did the brakelight mod the day I got PeeWee. I must have also done it to 20 or 30 other minis in the last few years.
That said, if you have some problem just take the jumpers out before you go to the dealer.
OTOH, if someone soldered a diode or something else in there there is no telling what they did and what they left exposed. But if there is a short, I can't imaging what could happen other than a fuse blowing.
Just my thoughts.
Rich
