Interior/Exterior Replacing H7 High Beams
I feel kind of dumb asking this question but, how do you remove the clip that holds the H7 high beam bulb in? I'm trying to replace my OEM H7s with some blue/white H7s.
I searched the forums and can't find any info that helps. I also know that I should buy the shop manual, sometime in the near future.
Thanks in advance.
Thanks in advance.
push the clip tab up towards the bulb and to tha side, the clip will release
Thanks in advance.
Thanks in advance.
Originally Posted by francois
I changed mine to Sylvania Silverstars. This the best simplest/best upgrade ever since the stock H7s are weak.
As for installation, I was worried about those wierd clips on my '06 MCS, too. I tried prying them apart, but they kept popping back in place before I could get at the bulb. Funny thing is, you don't need to move the clips! You just grab the back of the bulb and yank down at a slight angle. The clips are just springy enough that the bulb will spread them apart on it's own and come right out. Just make sure you have a good grip on the bulb and don't pull too much to the side, because when it pops loose, the glass part could smack the sides of the housing and break. Installation of the new bulb is basically aligning the tab between the clips and PUSH it home .... done!
Once you do this one time, you will understand. The second bulb took me all of 15 seconds to change.
Dec 23, 2015 10:36 AM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
