Code 1125 help
Old Dec 28, 2005 | 01:01 PM
SpiderX's Avatar
SpiderX
Code 1125 help
my car is throwing 1125 TB position sensor...... I cleared it multiple times and it keeps coming back. (limps and won't idle) the dealer says the TB is shot and needs to be replaced....it is a WMS unit...... surely there is another answer.
Old Dec 28, 2005 | 01:14 PM
Eric_Rowland's Avatar
Eric_Rowland
Does the dealer define what 'shot' means? Ask them if they know the failure mode (what broke) other than repeating "It's throwing code 1125 so we need to replace the TB".
Old Dec 28, 2005 | 01:26 PM
newbs49's Avatar
newbs49
SpiderX
Did you keep your old TB or did you give it to Randy for a core charge. I kept mine just for this reason. Hopefully Randy can get one overnighted to you before the weekend. Good Luck
Make sure you check the harness going to the TB. There has been some bad ones.
Old Dec 28, 2005 | 03:13 PM
SpiderX's Avatar
SpiderX
Originally Posted by newbs49
SpiderX
I sent back the core to randy...the dealer says the sensor is shot and part of the TB... can't be replaced by itself
Old Dec 28, 2005 | 03:32 PM
chows4us's Avatar
chows4us
Sorry to hear that
Old Dec 28, 2005 | 03:48 PM
newbs49's Avatar
newbs49
SpiderX
Did you get a hold of Randy? Hope you can get quick help from him. Good Luck.
Old Dec 28, 2005 | 03:51 PM
minicoop78's Avatar
minicoop78
what year is your car?
Old Dec 28, 2005 | 04:03 PM
Skiploder's Avatar
Skiploder
Spider:
The 02s and 03s have had issues with the part of the wiring harness that branches off to the throttle body.
Our local dealership confidently proclaimed that my aftermarket throttle body was taking a dump on me. After they replaced it with a stock one, they were utterly flabbergasted when it immediately threw the same codes. After many days of jumping up and down, beating their chests and throwing dung at the wall one of them had an original thought (or bothered to read their TSBs)- and replaced this portion of the harness.
Then again, I have never owned a BMW product that did not have the throttle body die within the first 30K miles of ownership............
Old Dec 28, 2005 | 04:21 PM
Tüls's Avatar
Tüls
Turbius Maximus
LOL WELL PUT!!! I love stuff like that!!
Old Dec 28, 2005 | 09:46 PM
SpiderX's Avatar
SpiderX
SpiderX
I left word at the shop... I have never had a code that after I cleared it came right back with "limp mode"....... usually it is a temporary situation and clear it once and it goes away....... The last problem I had that I could not fix it turned out to be the Unichip causing a code and they fixed it...... the one thing about all these mods is when weird s%$t happens it is very hard to trace the root of the problem. TB positon sensor.......?
Old Dec 29, 2005 | 05:20 AM
SpiderX's Avatar
SpiderX
Anyone else, maybe with a Bentley's manual (I need to get one)
Old Dec 29, 2005 | 06:25 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Ummm ... yeah, you do:
"02 MCS, Alta CAI, 19%, Mltk hdr/cat, WMS head/cam, Uchip, WMS TB, 400s, HS swy brs F/R, HS r cbr, WMS f cbr, RVF/T1S, AP BBK, r Pwr slots /2500, Alta SS/Whln, Pprt SR-7, bst/oil gages, PSS9, Mini rf rak, Pilo coil/nology, Alta IC, Aero kit, M7 CC, M7 scp, intk & runrs, M7 plsm bster, Alta crnk ply"
Old Dec 29, 2005 | 06:41 AM
chows4us's Avatar
chows4us
A and B Range/Performance Small Error
https://www.northamericanmotoring.co...ighlight=p1125
bad TB
bad TB wiring harness
Old Dec 29, 2005 | 06:50 AM
BigBrownDog's Avatar
BigBrownDog
This exact problem was resolved on my '02 MCS by replacing the throttle body. Note that my wiring harness had been replaced previously.
Old Dec 29, 2005 | 07:57 AM
SpiderX's Avatar
SpiderX
Originally Posted by chows4us
Thanks, I had read these before i posted....... i was hoping for a little more info....... I went to Rspeed and read the Bentley's, which was very disapointing....... why don't they call it "how to replace parts manual" I found it very lacking......(I will look for a deal on one on Ebay) In this case it was very unhelpful..... It appears the TB has taken a dump...... I have had this code before and after clearing the problem went away for long periods.... I felt like it came about when the "moon was in the 7th house" and had more to do with my mods not playing together in some unique condition. the condition did not come up very often...clear it and all was good. now the engine will not stay out of limp mode..... it is still 1125 only (small error)....not 1126 or 1226 etc.
Thanks to those who responded,,,,even if it was to tell me I should have a shop manual.
Old Dec 29, 2005 | 10:42 AM
SpiderX's Avatar
SpiderX
02
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
