Suspension Anyone with H&R Sway Bar? [No lubrication needed]
Hi
My H&R rear sway bar is in. Will get it fitted next week.
I still have some questions:
From H&R:
I read some ppl with other brands have problems (squeaks) with the sway bar because off not enough/wrong grease. So the H&R sway bar seems to be a good choice. No worries about lubrications/squeaks. Sounds really nice
Anyone with H&R sway bars? Does it really dont need lubrication? Any sqeeking after a few miles? Does it really works what they claims? Or should I use grease to be at the safe side?
From H&R:
H&R’s exclusive composite bushings (Urethane / Teflon) eliminate squeaks and never require lubrication. That means no mess, no maintenance—just bolt on H&R stabilizer bars and go!
Yep, got the 18mm 2 hole H&R on my Cooper (SS).
No grease, no squeak. Its been EXTREMELY cold 0F, -20C, no squeak. I had upgraded sway bars with polyurethane bushings in a Volvo 850 before, LOTS of grease, and they started squeaking when its really cold out after about 6 months.
So far, I must say the H&R works, I just love aftermarket mods where you install and forget about them
I never even gave this "squeak" a thought til your thread came up
Originally Posted by weezer2282
I wonder if its possible to use the bushings with other sway bars.
like which one?
Originally Posted by Maaij
So you guys dont have used any grease on it?
outside and bottom with white lithium grease.
my Atla started moaning earlier this year (first time a swaybar ever
made noise on me on any of my cars) and upon inspection, I found
there was plenty of grease on the inside and outside of the
bushings....but no grease on the bottom since I never actually
applied grease there.
guess wat, i put a dab of grease on the bottom and no more
noise.
outside, and bottom of bushings for all future installs.
Originally Posted by kenchan
be ****. even though you don't grease the inside, i'd still grease the
noise.
lessons learned. i will apply grease to the inside,
noise.
One more question
I read you are a big fan of white lithium grease
Is this in aerosol form?
Is this in aerosol form?Maaj- don't use it 'everywhere' it'll be a huge mess to clean up.
I have a problem of fixation...
jk i am open to newer lubes but white lithium is available everywhere
and worked the best so far. I use the one sold in a tube.
(but i do have the aerosol one too for quick fixes).
i also have fixation with de-greasers... I use RC car motor spray.
yep, your outside and bottom is what I was referring to.
Since H&R comments they don't require lubing on the inside, i would
just leave it as is with no lube to preserve watever their coating is.
hey kenchan:
A stupid duh question
Is this right?
Do I have to put grease here
Do you recommed to do the inside as well?
Is this right?
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
