Drivetrain ATT: BOTTLE HEADS nitrous consumption
Old Nov 20, 2005 | 09:19 AM
willy69's Avatar
willy69
i am thinking of using nitrous, how many times can you hit the steroid button before it's empty? what is the best set up? what is the best hp shot to use? any info would be helpful.
Old Nov 20, 2005 | 02:45 PM
Paul Webster's Avatar
Paul Webster
wet kit at about 70hp. We were using just under a 1lb a run (dragstrip)but performance will drop as you get to 5lb in a 10lb bottle
Old Nov 20, 2005 | 03:05 PM
isellem's Avatar
isellem
hey paul are u spraying out of the hole?
Old Nov 20, 2005 | 03:30 PM
autoxguy305's Avatar
autoxguy305
Do you have any pictures of your setup? I've put a direct port kit in my car, but i havn't installed it as i'm upgrading my fuel setup. I made a new 10AN fuel rail and will be running new 8AN line to and from my tank.
Old Nov 20, 2005 | 04:41 PM
spillman's Avatar
spillman
Just make sure your over all whp isn't over 250. If so then you will be needing pistons shortly. However once you have pistons then you are good to over 400whp. And then you will loose a head gasket if you go too far over the 400whp mark.
Old Nov 20, 2005 | 10:29 PM
BFG9000's Avatar
BFG9000
When jetted for 50hp, nitrous will flow at about 2lbs per minute so a 10lb bottle lasts 5 minutes until empty, running more and more rich toward the end (approximately $10 per minute). It's like renting a turbo...
At 100hp a 10lb bottle lasts 2.5 minutes
At 200hp a 10lb bottle may well last longer than the engine
Those are the main problems with nitrous; when you really want to use it, the bottle is invariably empty. And it is soo easy to get a little too greedy with the jets.
Old Nov 21, 2005 | 12:07 AM
Paul Webster
Isellem,
We tried but any activation in 1st some of 2nd gave us wheelspin or axle tramping(fwd and backwards rather than up and down). The car is very track dependant at our RWYB 300fwd cars lifting the rubber off.
We have now bought a NX/FJO controller to cure that problem, so hopefully will be using some/alot out of the hole in a controllable manner. Its a wicked bit of kit check it out www.fjoracing.com.
We will be starting out the year on slicks though as the track won't be good until Easter, then we'll put the drag radials back on, then again maybe we wont
How the hell you're going to activate the nitrous with no lsd and on those old street tyres is beyond me
Good luck
Old Nov 21, 2005 | 12:23 AM
Paul Webster
Autoxguy305,
When you say a direct port kit do you mean you have 4 foggers or 1 fogger
Old Nov 21, 2005 | 06:07 AM
willy69's Avatar
willy69
very helpful info, thanks guys
IQRaceworks
53
Jun 28, 2024 07:29 AM
sempaipaul
Oct 26, 2015 05:56 PM
Fordgt4
Oct 10, 2015 10:42 AM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
sempaipaul
Sep 9, 2015 05:55 PM
