how many of you have this: 42 mm offset wheels with 215x45x17 tires
42 mm offset wheels with 215x45x17 tires and stock suspension? i'm buying new tires and want to go wider, but don't want any problems. thanks in advance.
17" rims with +42mm offset and 215/45-17 tires will work with stock suspension and NOT rub.
Once you lower your MINI then you are at risk of rubbing but it depends on which tire you have, it's size/side wall height, your camber and how much drop you have.
PSS9 and other coilovers allow for some adjustment of ride height so you can make it not rub.
Don't go wider if the 215/45-17 will suit your needs. 225/45-17 sounds nice but the outer tire diameter is a larger than stock 25" which when combined with lowering springs will result in rubbing not to mention the tire itself is wider than stock.
I have 17"x7" ARE Chrome Coils 42 mm and 215/45-17 F1 GS-D3 with stock suspension and no rubbing in 2 weeks.
Tonight I installed my front PSS9's, will do the back tomorrow night but I'll have to set the height as it is way too low
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
