Navigation & Audio HK is on but no sound
Old Aug 28, 2005 | 07:49 PM
MSFITOY's Avatar
MSFITOY
Little help guys...I was running my HK kinda loud and it was hot out. After a while the sound shut off. The head unit still displayed and changed channels, etc. but no sound. I waited 6 hours for it cool down but the sound is still gone. Please tell me there's a blown fuse somewhere and that I didn't fry the amp
Old Aug 28, 2005 | 07:53 PM
kaelaria's Avatar
kaelaria
There's a blown fuse somewhere and you didn't blow the amp.
Old Aug 29, 2005 | 05:39 AM
MSFITOY's Avatar
MSFITOY
bump...
Old Aug 29, 2005 | 06:18 AM
mikem53's Avatar
mikem53
You need to find out if the output section of the amp is fused. It will most likely require that you remove the HU to reset it. Worst case is that you fried the output section.
Good luck
Old Aug 29, 2005 | 07:46 AM
Maximusmini's Avatar
Maximusmini
I highly doubt you burned the amp. I've been blasting my HK for all of the 6k miles that i had Vader for, except for the Dyno Time.
Old Aug 29, 2005 | 07:51 AM
MSFITOY's Avatar
MSFITOY
alone in the dark once again......................................
Old Aug 29, 2005 | 10:15 AM
not-so-rednwhitecooper
doesnt the HK amp have another fuse in the fusebox? i think it does....
anyways, when i crossed some wires from the HK amp when i wired in new speakers, the rear chanel went dead. i had to disconnect the amp with the connector on top and it reset.....maybey you just need to disconnect and reconnect the amp.
Old Aug 29, 2005 | 06:48 PM
MSFITOY's Avatar
MSFITOY
I rarely ask for help but...
you guys are letting me down here I can't believe there aren't more sound experts out there.
Help me brainstorm please...I checked in the Bently, useless.
I turn on the system today, got a brief broadcast from FM and then couldn't repeat. It's silent except for a steady, quiet "thud" every 5 seconds regardless whether it's in CD/FM/AM/XM. When I accessed the bass/treble/fade control, I noticed that the HK parameters are not there on the display Sup
Old Aug 29, 2005 | 06:53 PM
sounds like a problem with the amp to me. DID YOU TRY TO UNPLUG IT AND PLUG IT BACK IN YET!!!!?????
Old Aug 29, 2005 | 06:56 PM
MSFITOY's Avatar
MSFITOY
I guess it couldn't hurt. It's a good thing I've got another Great sound system out the back end
i bet its the problem, if it is, forward 5 dollars to my paypal account
Old Sep 1, 2005 | 05:41 PM
MSFITOY's Avatar
MSFITOY
The Amp is buried in the right rear boot and there a screw I can't reach. I tried but am not in the mood to remove half of the rear end to get to it
Help
Old Sep 1, 2005 | 06:17 PM
pull the seat, pulle the bottom seat, pull the center rear cover around the latch, remove 3 screws, pop off 1/4 cover.
Old Sep 1, 2005 | 06:22 PM
MSFITOY's Avatar
MSFITOY
AAAAGGGG....I'm not following you I can replace the header with my eye closed...but I'm not getting what you're talking about
Old Sep 1, 2005 | 06:39 PM
son of a..... it just deleted my entire post
stupid crap
1- remove back seat
2- remove weatherstripping around hatch
3- remove latch cover at the bottom of the hatch, its the long L shaped plastic piece
4- remove the 3 screws holding the 1/4 cover on.
5- pop off the 1/4 covere, there are clips all the way around
6- inspect amp, you dont even need to unscrew it, its all right there then.
Old Sep 1, 2005 | 06:42 PM
MSFITOY's Avatar
MSFITOY
Thanks so much I guess I don't have a choice but to remove the entire rear end from the sound of it LOL
Old Sep 1, 2005 | 06:49 PM
its really not that bad
the first time my parents saw it all out, my mom had a sh*t fit, lol
it looks worse than it is, its probably an hour to 1 1/2 hour job.
Old Sep 1, 2005 | 06:53 PM
MSFITOY's Avatar
MSFITOY
Oh...no problem then. About how long it takes me to do two headers Seriously, thanks I'll just have to get to tomorrow whether I like it or not:smile:
Old Sep 1, 2005 | 07:07 PM
no problemo man, if you need any more help, gimme a hollar, i can just walk you thru it, ive done it quite alot
Old Sep 3, 2005 | 10:05 AM
MSFITOY's Avatar
MSFITOY
Well, no go...I got it out, disconnected/reconnected and nothin I HAD to be the first to fry an amp I hope MINI will service it out of the car
Anyone have a spare HK amp lying around?
Old Sep 3, 2005 | 12:21 PM
MadisonMini's Avatar
MadisonMini
I'm getting a new HK amp installed in my 2005 MCSC. After about 30 minutes with the volume LOUD, top down and hot weather, the sound will wildly fluctuate. It sounds like crap. Very muffled. I called my dealer and told them I think my amp has gone bad. They ordered me a new one, getting it installed 9/21/5 (along with a new top).
Old Sep 3, 2005 | 01:59 PM
kazlot's Avatar
kazlot
H/K on but no sound
Posted on 9/02/05 by kazlot
Radio just died!
Was leaving the dealership yesterday after a service and my radio and trunk mount changer would not play. The head display was still working and the controls still worked but no sound. As it turned out the H/K amp in the boot died. There had not been any problems with the radio or changer before yesterday.
According to the tech. the radios allways crap out after an air filter change!! Ha Ha.
They changed the amp (no charge) and commented that tha H/K amps die with no warning. Good luck with your problem, maybe it will be easy like mine.
It's not a fuse somewhere, you did blow the amp. Sorry about that!
Hope this helps...
Colt45Magnus
Aug 27, 2024 05:03 AM
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
atlantaorange
21
Oct 2, 2015 12:32 PM
Joeygonz
Oct 2, 2015 11:24 AM
