Look what hit me in the foot while driving home tonight. Anyone know what it is?
Old Aug 19, 2005 | 09:18 PM
BuckeyeMCS's Avatar
BuckeyeMCS
It hit me on my left foot. What is it and can I drive without it?
Old Aug 19, 2005 | 09:21 PM
goaljnky's Avatar
goaljnky
This is just a guess, but it looks like a spring?
Old Aug 19, 2005 | 09:24 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I believe that might be your clutch pedal return spring. Gotta do some research!
Old Aug 19, 2005 | 09:28 PM
not-so-rednwhitecooper
or simply look under the dash....you can see both brake and clutch return springs
Old Aug 19, 2005 | 09:30 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
I have paged Dr. Greatbear and he will be here shortly!
Clover
Old Aug 19, 2005 | 09:33 PM
supersand's Avatar
supersand
http://www.realoem.com/bmw/showparts...67&hg=35&fg=05
As someone mentioned earlier
Clutch COMPRESSION SPRING
Erik
Old Aug 19, 2005 | 09:58 PM
Greatbear's Avatar
Greatbear
It's IS the clutch pedal return spring. Here is a huge-*** pic:
This is the view behind the knee bolster/parcel shelf (whichever you have), at the point where the clutch pedal hinges. This spring gives the 'over center' feel as well as the return. Should not be a big problem putting it back in, inless something broke, which is somewhat likely (especially at the plastic pedal arm). If it's under warranty, I'd take it back to the dealer if something has indeed broke or you dont want to fool with it.
Old Aug 19, 2005 | 10:53 PM
markbradford's Avatar
markbradford
Uhhhhhhhhhhhh, did the clutch get floppy after it fell on your foot?
Old Aug 20, 2005 | 04:00 AM
BuckeyeMCS's Avatar
BuckeyeMCS
I have had a problem with the clutch feeling notchy for a while. Dealer (MAG) says it is normal. So it felt ok. I will have a look under the dash. I would think it would be OK to drive. I have a dealer appointment Wednesday anyway.
Old Aug 20, 2005 | 04:13 AM
62Lincoln's Avatar
62Lincoln
Flux capacitor?
Old Aug 20, 2005 | 06:17 AM
Gr8Force's Avatar
Gr8Force
Nah, that's the framostat. Hooks up the thingamuhbobber to the whatchamacallit so the doodleyhickey can oscillate. Ahaight?!!!
Old Aug 20, 2005 | 06:32 AM
mikem53's Avatar
mikem53
looks like a clutch assist spring, Your clutch will require more effort to depress... if it is that spring.
mike
Old Aug 20, 2005 | 08:15 AM
petecrosby's Avatar
petecrosby
mike
I would suspect less effort as that is the return spring.
Old Aug 20, 2005 | 12:40 PM
kenchan's Avatar
kenchan
dang, came here too late. I saw that return spring on the clutch pedal while I was working on moving my PIAA switch the other evening... oh well. :smile:
Old Aug 23, 2005 | 10:29 AM
BuckeyeMCS's Avatar
BuckeyeMCS
Less effort for sure. My the clutch is sooo much smoother now. I don't understand why it came off...
Old Aug 24, 2005 | 05:52 AM
Pebblecrusher's Avatar
Pebblecrusher
My spring also came off at one point. One of the connectors holding it in broke, and the dealer repaired it under warrenty. The clutch felt about the same without it, except for a slight click about halfway.
Old Oct 23, 2007 | 07:05 PM
goldcountrymini's Avatar
goldcountrymini
my clutch compression spring is off on one end... Anyone know if it's safe to drive with it not connected? I don't feel any difference in the clutch pedal.
ebowling
90
Aug 4, 2019 09:15 AM
theblackfalcon
Oct 11, 2015 09:49 AM
portedbuckle
Sep 11, 2015 07:02 AM
clintmeister
Aug 12, 2015 11:11 AM
kpl
Aug 11, 2015 04:52 AM
