Shark Injector
Old Aug 6, 2005 | 02:13 PM
trickedmotoring's Avatar
trickedmotoring
Shark Injector
has anyone used the Turner motorsport shark injector. does anyone have any feed back on its performance, also comparing to other ecu upgrades.
also where can i find the mth software. im new to the mini tunning world.
thanks.
Old Aug 7, 2005 | 12:22 AM
Bakerman's Avatar
Bakerman
I got it a little while ago, I have a cia and a borla exhaust also. For the money I think it was worth it. It's got a noticable difference in power, which makes it feel a little more peppy. It was real easy to install, but they tell you to use a battery charger while installing so that it will have the proper amount of power while reprograming. If the voltage drops below a certain point it won't finish the job. All in all I'd recommend it.
Old Aug 7, 2005 | 09:46 AM
trickedmotoring
thanks
Old Aug 16, 2005 | 08:20 PM
1FSTMINI's Avatar
1FSTMINI
Is the Shark injector year specific???
My friend had one burned to his spec which im buildin mine the same way and hes not goin with that program anymore and i wanted to use it....Mine is a 05 and his is a 03 i think.
Old Aug 16, 2005 | 09:51 PM
Bakerman's Avatar
Bakerman
Don't think it's year specific, but I had to chose between 91 or 93 octain. Once you use it on one car it can't be used on another one. It has something to do with the info it gets off the old program that will only work with that specific car.
Old Aug 16, 2005 | 10:19 PM
1FSTMINI's Avatar
1FSTMINI
Well that sux......He was telling me when it loads it program it will d/l the original one to the shark until u wanna go back to stock again.....ill find out if i can flash mine being hes not using it anymore.
Old Aug 17, 2005 | 04:25 AM
jonnieoh's Avatar
jonnieoh
Read up about it on the web site for the Shark Injector. They do that on purpose; for two reasons:
1.) They get to sell a lot more Shark Injectors, and therefore make more money
2.) They argue that each and every MINI is slightly different in the way the engine performs. Therefore, every MINI owner who wants Shark Injection, should theoretically have their own injector, so as not to confuse your car's computer, or damage it in anyway, by replacing your original programming with a friends' programming, should you use their injector...
I think that sounds logical, and I believe it, but it also might be B.S. to justify everyone having to have their own.
P.S. I don't own a Shark Injector, but I've been very tempted to get one!
Old Sep 19, 2008 | 05:25 PM
GatorS's Avatar
GatorS
I currently have a Shark Injector and it is installed on my 03 mini cooper s. I have all the bolt ons such as intake, catback exhaust, 15% pulley, etc. I am looking into installing a set of OBX headers and an Ultrik cam that is similar to the Schrick. Will all of this work with my current shark software? Will conforti update the software for me? And, I was also considering a GIAC tune...what will be my best route?
Old Sep 19, 2008 | 05:59 PM
minimarks's Avatar
minimarks
# 1 ECU upgrade = Jan Tune.
Old Sep 19, 2008 | 10:40 PM
GatorS's Avatar
GatorS
How do I get a Jan Tune? I googled it...no luck. I really dont want to remove the ECU and mail it...I'd much rather just drive a couple hours and have the work done if possible. How much better is the Jan Tune than the GIAC?? Thanks for the help guys.
IQRaceworks
53
Jun 28, 2024 07:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
randeez
Oct 5, 2015 09:23 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
