Help! Intake hose clamp
Old Jul 22, 2005 | 01:35 PM
hyobum's Avatar
hyobum
Someone please explain how to put the intake hose clamps back together. I tried pulling on it as hard as I can and it won't go back to ts original position..
Old Jul 22, 2005 | 01:41 PM
lsd05jcw's Avatar
lsd05jcw
its very difficult, although possible using a needle nose and screw driver. I held one side/end of the clamp in position and pushed the other end of the clamp over the clip with a screw driver. Got lucky I think. Thus, I got one together and but another I couldn't. I recommend buying a quality hose clamp in the correct size through a auto parts store and use that..... It's easier and you can remove it again if needed....
Old Jul 22, 2005 | 02:00 PM
haulinS's Avatar
haulinS
I agree, the OEM hose clamps suck!!
Old Jul 22, 2005 | 02:14 PM
OKeefe's Avatar
OKeefe
Option....
A large zip-tie works
this isn't a connection that gets a lot of pressure....
I discovered this same fact - the factory clamp is a 1 time deal - couple of weeks ago when I replaced the stock airfilter with a K&N ....
there's only about 1000 other zip-ties in the engine compartment...what's one more?
{zip-tie = nylon cable wrap ....}
Old Jul 22, 2005 | 04:05 PM
jimz68's Avatar
jimz68
The clamp is re-useable. See this thread:
https://www.northamericanmotoring.co...ighlight=clamp
Old Jul 22, 2005 | 05:39 PM
kenchan's Avatar
kenchan
You probably broke it (bent it) when you pulled on it as hard as you can.
Just go to a hardware shop, look in the septic pipe/gutter aisle and get
your large hose clamps. :smile:
Old Jul 22, 2005 | 10:10 PM
hyobum's Avatar
hyobum
Aha! I didn't break it, I actually put it back together. I tried pulling on it from only one side, so that was why it didn't work too well. I used a needlenose plier to just squeeze the hook and the bump, just a little twist, click! It would be much easier if I had something that can grip the clamp better.
Old Jul 23, 2005 | 09:11 AM
jimz68's Avatar
jimz68
This is what I use. Works great.
http://www.tools-plus.com/cha424.html
Jim
rtk90
Aug 29, 2019 09:08 AM
Sep 11, 2015 11:09 AM
makg
Sep 10, 2015 11:59 AM
kjd186
Sep 9, 2015 10:02 AM
eliseo1981
Sep 4, 2015 02:33 PM
