Ecu removal
Old Jul 21, 2005 | 09:18 PM
memojo's Avatar
memojo
Ecu removal
To remove the ecu (after the covers are removed), do you just pull up? I can't seem to ge the part unplugged. Would gently using pliars help?
Thanks.
Old Jul 21, 2005 | 09:40 PM
supergimp's Avatar
supergimp
There are two plugs with tabs that are pulled fore and aft. See the How-to on webbmotorsports.com on CAI install for details. That's how I figured it out. Don't try to yank the connectors, they won't budge. The tabs unlock and release and, in everse, seat the connectors and lock them in.
Steve
Old Jul 21, 2005 | 09:42 PM
kenchan's Avatar
kenchan
you have to pull the large tabs on the plugs horizontally and it will
unplug and raise upward by itself as you pull.
I don't know about the MC, but on the MCS, you pull the front plug's
tab forward toward the bumper, the rear plug's tab towards the
front windsheild.
Is that wat you're asking for?
Old Jul 21, 2005 | 09:43 PM
Dr Obnxs's Avatar
Dr Obnxs
No Pliers!!!!!
Where the wires come out of the two connectors on the top, there is a plunger on each connector. It's a lighter grey.... Pull this back. A LONG way. It will release the connector. Go to my gallery, and look at the PLX stuff, and there is a photo that shows the plunger pulled back with the cover off the connector.
Good luck. It's a snap once you've done it once....
Matt
Old Jul 22, 2005 | 03:13 PM
memojo's Avatar
memojo
Thanks, everyone. I'll let you know how I make out.
Old Jul 23, 2005 | 11:16 AM
memojo's Avatar
memojo
Removal success!
Thanks for the advice. It worked like a charm.
Old Jul 23, 2005 | 11:26 AM
kenchan's Avatar
kenchan
09R56
Nov 16, 2022 10:49 AM
DeniseNY R52
May 17, 2016 05:16 AM
AdrenaliNate
Nov 4, 2015 07:26 PM
Crimguy
Sep 10, 2015 01:07 PM
greekzilla
Aug 23, 2015 03:44 PM
