Drivetrain question here... knocking
Old Jun 30, 2005 | 03:16 PM
warchieft2k's Avatar
warchieft2k
Hello... how do i tell if my engine is knocking??????????????????? jeje i feel a little dumb asking
Old Jun 30, 2005 | 03:46 PM
BFG9000's Avatar
BFG9000
The knock sensor in a Mini should allow the computer to prevent any knocking period. If you add noisier engine parts a knock sensor may be fooled and timing may be dialed back unnecessarily, but there still will not be any knocking.
If it is not a Mini you are asking about.... knocking at part throttle usually sounds like shaking marbles in a coffeecan and you'll hear it. Knocking at full throttle may be inaudible due to all the other noise at full throttle but don't worry you'll know about it soon enough because the car will be broken down on the side of the road
Old Jun 30, 2005 | 06:04 PM
Jayar's Avatar
Jayar
Do you think you heard it knocking or are you just curious? I once thought my engine was knocking and found that the belt tensioner was loose. I think that's what it was, but it was making metal on metal contact. The resulting knock was disheartening. Fixed under warranty. HTH. JR
Old Jul 1, 2005 | 06:27 AM
warchieft2k
well the thing is that i got a new MTH map and franz told me that if knocked to send it back... so im wondering if ill be able to tell...
Old Jul 1, 2005 | 05:11 PM
BFG9000's Avatar
BFG9000
Then you are running extra advance and the knock sensor may have been "desensitized" a bit. Listen for rattling when on the gas (even under light load) and especially when tipping into the gas. It would be very important to note exactly when a rattle is heard so it would be possible to dial back timing only there.
donniedarko
Oct 21, 2015 01:15 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
tylewis
Sep 6, 2015 01:07 PM
MasterShaftner
Sep 4, 2015 03:52 PM
