Drivetrain Aftermarket exhaust and waranty issues.
I am looking for a nice sounding exhaust for the 06 MCS i'l be ordering soon. I will be doing a 15% pulley and CAI later on, but for now i want to keep my car mostly stock to avoid the waranty issues that may insue. I've looked around and i like the Borla Sport exhaust. My only concern is the waranty. Would the dealer only void the part of it related to the exhaust? Also, if they were to void the Borla, what would be the dealer's reaction to a one-ball exhaust?
-Blake
-Blake
A one ball is just a cut up version of the stock exhaust, so yea, you'd definately be without a warranty on the stock exhaust once you get done with the sawzall and welding rods. Best bet is to get an aftermarket cat-back, and keep your stock exhaust or throw it away like the rest of us). There is really nothing to void with a cat-back, as there ain't no movin' parts on one, properly installed that is. The stock exhaust sounds sweet, as does the Borla, Miltek, Magnaflow, Scorpion/PlayMini, UUC, the list goes on and on. Listen to some in between now and when you get your MINI to help you define what you want, as an exhaust is personal choice. Go to a MINI meet or find someone in your area with one of the 'forementioned cat-backs and go for a ride.
Borla Issues
Blake,
I'd recommend you stay away from the Borla. It looks and sounds great, but in my experience is not the quality product it used to be. In fact, I've had my Borla exhaust welded twice. The hangers came right off both sides as if it were paper. Then when I called their customer service dept they told me welding it voided the warranty. That's BS! If I hadn't had it welded back together it would have ripped right through the little aluminum exhaust under pan/cover.
Anyhow, if I had to do it over again I'd stay away from the Borla and suggest you do the same.
A
A
-Blake
-Blake
MGCMAN: Thanks for the advice. I have driven a MCS in the past and i did like the sound. For now, im just trying to start the moding process while trying to keep my waranty intact. I love the sound of the borla, but i will look into some other options. I will probably give the Alta exhaust some serious thought as well.
AMPR: Thanks for the warning. All i know about the Borla is that it sounds great. I had no idea the quality was so bad. What do you think about the Alta or Miltec?
thank you
Blake
thank you
Blake
Your dealer has no right to void your warranty from an exhaust. They have to prove that the exhaust was the cause of the problem. If they claim its the exhaust then i would question their ability to peform the work as they are not very bright in the first place. The Magnuson-Moss Act is your friend and protects you the consumer from the dealership trying to pull your chain.
Garrett
Garrett
If you swap out the exhaust system, the only warranty that will be voided is on your stock exhaust system. So there are no worries anyway since you want to replace it! As the primary function of sitting underneath the car and channeling the exhaust gases out the back, dealerships would be hard pressed to pin a failure on the exhaust system.
CooperSAZ,
I agree and forgot to add what you stated. The only thing that they will not cover is the exhaust itself. Since you removed that part from the car. Why should they have to cover that aftermarket part? But they can not assume that the aftermarket part was the cause of another problem with out backing up their claim with hard proof.
Garrett
Garrett
The only time I have heard of a warrenty issue regarding exhaust was with regards to a WRX. This young man , not a kid went in with a cat back system and a blown clutch. Subaru claimed that the extra HP made my the cat back voided the power train warrenty. Subaru has been on a rampage since the WRX/ STI came out regarding warrenty issues so this is not a indicator of what Mini would do. I have not heard of any problems with mini exhaust modifications. Now the 19% pulley , That is another story.
Well, i dont want to start the pully conversation (yet
). I know I will do that at some point, but i also know that is a guranteed warranty voider. Im already geting ready for the CAI, injectors, ECU and 15% pulley for the day my warranty is up.
From that you have told me, the Miltec is quitet... The reason i liked the borla was the fact that it was loud. What would you recommend instead of it to allow for a nice loud tone? And please dont say Magnaflow.
). I know I will do that at some point, but i also know that is a guranteed warranty voider. Im already geting ready for the CAI, injectors, ECU and 15% pulley for the day my warranty is up.From that you have told me, the Miltec is quitet... The reason i liked the borla was the fact that it was loud. What would you recommend instead of it to allow for a nice loud tone? And please dont say Magnaflow.
Originally Posted by garretwp
CooperSAZ,
Garrett
Garrett
) I also heard that Mitsu has representatives going to various tracks (1/4 mile tracks) in some states writing down VIN numbers of Evos that are in the staging lanes...
MINI is pretty laid back for the most part...
I don't understand the "dealer has to prove it screwed the car" defense. I would imagine that at servicing the engine, the dealer would simply either refuse the service without an understanding that the customer pays, or perform the service and then hand the customer the bill. The whole deal becomes the customer's burden. The "defense" may ultimately succeed in a court case
, but who wants to go there? I would suggest talking to your dealer before doing a mod and getting their agreement in advance about your warranty coverage.
What "the dealer has to prove it....." means that if the dealer refuses to do warranty work on your car becuase of an aftermarket part installed and they have no proof that the part caused damage to what needs to be repaired under warranty, or refuse to give you any reason other then it being present on your car, they are technically breaking the law. The Magnuson-Act proctects the consumer from having that happen to them. Many people do not know about this act and give in on the dealer for false reason. If you do a google search for the Magnuson-Act there are many sites that will break it down for you and tell you what it all means.
Garrett
Garrett
There's even a link to it here.
I agree with you that there are consumer protections under the federal and state statutes. But if you are asserting their protection, it likely means that you are in court with the dealer.
Litigation over my xxx h.p. upgrade would just ruin the great cosmic wa.
I am just suggesting that an understanding up front is happier than a dispute when the deed is done.
As far as the Milltec being "quiet", I'd say it's mellow, deeper in tone than a stock exhaust. It will not get tiring in the long run. I've heard other brands that are louder, but to me they would be a little "boomy" for a long drive.
ltjpunk7
Sep 6, 2015 07:32 AM
