R50/53 Egghead Alert: Check Tire Pressure!
Old Jun 2, 2005 | 08:47 PM
ZenAudio's Avatar
ZenAudio
Uh, I be the egghead on this one. My tire pressure light went on recently - second time in a month. Found a nail the first time and had the problem corrected - or so I thought. I never doublechecked the tire pressure from the shop. Noticed handling getting a little looser - figured it was my runflats getting fairly bald - then tire pressure light goes back on. This time I have my tire pressure gauge in the car. Don't see any of the usual suspects but check rear left and get a 0 reading. Check the other three and all are at 21 lbs. And I drive some serious twisties to and from work everyday.
Moral of the story. When checking the oil each fill up, check yer tire pressure and you may actually get your handling back.
Egg on face, go easy on me, it won't happen again.
Mike
P.S. As much as I'd like to deep six the runflats, they've saved my butt quite a bit already. I'll take a harsher ride for the security of running at zero pressure!
Old Jun 3, 2005 | 03:41 AM
mdsbrain's Avatar
mdsbrain
You see runflats are a good thing:smile: I am happy my car has them.
Old Jun 3, 2005 | 05:59 AM
Tarzan's Avatar
Tarzan
Tire pressure
Great advice! Just be sure to check your air pressure with a good quality gauge, and throw out the cheapie pencil-style gauges you get from the checkout counter.
Also be sure to reset the runflat monitor after adjusting air pressure, rotating, or installing tires.
Old Jun 3, 2005 | 06:55 AM
kenchan's Avatar
kenchan
when I took delivery my DSST SP9000's only had 25lbs in them...
Old Jun 3, 2005 | 07:16 AM
ZenAudio's Avatar
ZenAudio
That would probably be close to where my tires were at since the three good ones were all right on 21. I always hear stories here about not trusting dealers to have the basics taken care of, but I have finally learned my own lesson.
Mike
Old Jun 3, 2005 | 07:17 AM
spav's Avatar
spav
Was that wrong? I think the tires should only have between 25/30 in them. What's the pressure chart say in the manual/door jamb. I think it depends on the tire size and load in the car. My 16 in. chart says 26 PSI, so if you have 16's that's not too far off.
Old Jun 3, 2005 | 11:21 AM
ZenAudio's Avatar
ZenAudio
38 for 17" runflats
The 17" Dunlop 9000 runflats on the S are supposed to be 38 all around according to the door.
Mike
Old Jun 3, 2005 | 01:19 PM
eVal's Avatar
eVal
Its definately a good lesson to remember. It's funny, even though I have had plenty of low pressure situations over the years I probably still do not check it quite as often as I should - I partially chalk it up to stations having poorly located and/or inoperable air refill equipment; it seems like the air pumps don't even work half the time
As for the runflats helping or not, IMHO I found the fact that they disguised the pressure more then regular tires a downside. With normal tires I can often visually tell when they are lowish, and it seemed easier to feel the difference as well. On a reg tire you never could have gotten to 0 pressure without noticing well before then But in any case, it doesnt matter if you check them a lot I guess
Old Jun 3, 2005 | 01:25 PM
mielnicki's Avatar
mielnicki
Mike
Be very careful with the Door Plate pressures.
Read this:
https://www.northamericanmotoring.co...ad.php?t=44330
Steve
Old Jun 4, 2005 | 07:28 AM
ZenAudio's Avatar
ZenAudio
Good point
Steve
After reviewing the manual, the recommended pressure for 2 or less is 33 and for 4 and luggage - 38. The door is reflecting the max load situation and I am always at the lesser level so I have readjusted to 33.
Off to the twisties!
Mike
Old Jun 4, 2005 | 07:32 AM
ZenAudio's Avatar
ZenAudio
I agree the runflats can disguise the problem, but if I had regular tires I may have been sitting by the side of the road waiting for the tow truck. Slow leaks, however, do give you a visual warning.
Mike
Old Jun 5, 2005 | 01:12 AM
Xman's Avatar
Xman
I got fooled by the runflats as well ....just the old habit of the visual check until one day I realized it doesn't work with runflats (silly me!). My tires were around 20 psi (shame on me), quickly corrected to 33.
Now I do a weekly check.
TJANK
Aug 24, 2015 06:11 PM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
