EBC Green Pads - with or without sensor hole?
I have ordered a 2005 Cooper S automatic. I'm wanting to put in EBC Green pads as soon as it arrives but have noticed that at least one supplier shows them with and without sensor holes. Which ones do I need? Will it hurt just to get the ones with sensor holes even if I don't need them?
Its not really a hole, more of a knotch in the brake pad backing plate. Mine didn't have the knotch so I had to zip-tie the wear sensor to the brake line. No big deal if you remember to check your pad wear every now and then.
Here's a small post I put up on MINI2 about this:
I'm not sure about the rest of the world, but in the U.S., all 2003 and on MINI's have the wear sensor on the front. 2004 and on MINI's all have the wear sensors on the front AND the rear. Most aftermarket brake pads for the MINI (Mintex, EBC, etc.) are available with the slots for the front sensor to fit into. However, at this time, the ONLY aftermarket pads that offer the slot for the rear wear sensor (that I'm aware of) are the EBC's.
I have a set of the rear EBC Green Stuff pads on my 2005 MCS and they do indeed have the slots (the pads with the wear sensor slots are brand new and so if you order them, make sure that you specify that you need the rear pads with the sensor slot as you may end up with older stock that doesn't have the slot - that's what happened to me and I had to go through the hassle of sending them back for replacement).
Personally, I don't think the rear sensor is that big of a deal (you can just zip tie it back out of the way and be done with it). How often do your rear pads wear down anyway??? In my opinion, the EBC Green Stuff pads stink. I'm very disappointed with them. The main reason I bought them was to cut down on brake dust. However, they're no better than the stock pads really (and they seam to squeal really bad too). I really like the Mintex Redbox pads as they're MUCH better on reducing the brake dust and they're half the price (or less) of the EBC pads. If I had to do it again, I'd use the Mintex Redbox pads on the front and the rear and just bypass the wear sensor on the rear. Just my $0.02.
I hope this helps some...
Originally Posted by TheOfficeMaven
Personally, I don't think the rear sensor is that big of a deal. . . . . How often do your rear pads wear down anyway???
Originally Posted by ditc
Not all US spec.... my early build (Feb 03) MCS does NOT have wear sensors at all.
Originally Posted by Kendel72
is the green pads the only pads that really cut down on dust
Just my $0.02...
In my opinion, the EBC Green Stuff pads absolutely SUCK at cutting down the brake dust.
I guess I'm just biased since I buy pads to improve braking, no the appearance of my car.
Originally Posted by rmorin49
Do these pads have the wear sensor notches in both F&R pads? I have an 05 MCSc. Thanks.
Alex
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
Aug 25, 2015 09:18 AM
