R56 Secondary catalytic converter
Old Jan 17, 2026 | 10:03 AM
m4iled's Avatar
m4iled
So I just took my car to a muffler shop and cut out my secondary catalytic converter. I have 2013 r56 JCW.
To everyone’s surprise there is nothing in the catalytic converter! The thing is literally just a straight pipe with the outward appearance of a catalytic converter.
my problem is I just paid someone to remove this, when this could have been very beneficial to me, as I live in California, and recently passed smog testing as well. The straight pipe they now added is making an odd sound, probably due to bad welds? or the material?. Any idea what it is or what I should do? Kind of a bummer I just cut out the secondary cat all for it to just be a straight pipe anyway.
Old Jan 17, 2026 | 10:31 AM
Raymo2u's Avatar
Raymo2u
I believe that was a resonator, not a Cat
Old Jan 17, 2026 | 03:48 PM
m4iled's Avatar
m4iled
Nah it is the secondary catalytic converter. I’ve had the resonator and muffler previously deleted. I’m curious if anyone has had a similar issue where the contents disappear inside of it.
Old Jan 18, 2026 | 04:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Are you the original owner? If not, the previous owner probably hollowed it out and left it installed to make it “Look” like it had the second cat…. That would be my guess
Old Jan 18, 2026 | 02:05 PM
Frank_Repair's Avatar
Frank_Repair
Yep, that’s normal. the secondary “cat” on these is basically a dummy. If the new pipe sounds off, I’d take it back and have them check the welds or swap to a resonated section.
Old Jan 18, 2026 | 10:50 PM
m4iled's Avatar
m4iled
interesting to say the least. I got faked out by own exhaust lol. I’m going to take it into the shop later this week, maybe change the piping diameter all the way through.
Old Jan 19, 2026 | 05:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
No, nope, wrong. The secondary cat is NOT fake or empty or a "dummy" cat.
Take a look at this picture of OEM stock mid pipe:
In this picture, the left side is where it clamps to the down pipe. (For the OEM system, the primary catalytic converter is in the down pipe. The cat in the down pipe is monitored for engine operation by the two O2 sensors.) In the picture above, exhaust flows from left to right. The right end in this picture connects on to the rear muffler. Again, moving from left to right, the components are as follows: flex pipe, secondary cat, resonator. The resonator is a flow through device, and is "empty" when looking through it. The secondary cat is NOT empty, but has catalyst materials inside, just like the primary cat in the down pipe. If your secondary cat is "empty," someone did something to it - either replaced it or hollowed it out.
Old Jan 19, 2026 | 12:07 PM
m4iled's Avatar
m4iled
oh shoot, I think the secondary cat must of been cut out, It must be the flex pipe off that I took off. What is the function of this piece?
Old Jan 19, 2026 | 12:36 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The flex pipe section allows for movement of the exhaust and to prevent any cracking.
Old Jan 19, 2026 | 02:13 PM
m4iled's Avatar
m4iled
thank you just figured that out 😩. Just got a new flex pipe and tips installed for a pretty good deal I’d say. They told me get the downpipe and we do that too, man LA is wild.
Old Jan 20, 2026 | 05:40 AM
cristo's Avatar
cristo
Alliance Member
The JCW exhaust doesn’t have
a secondary cat.
Old Jan 20, 2026 | 05:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
a secondary cat.
Again, not entirely true.
The early N14 JCW cars had a large resonator with no second cat. Those early cars also had a multi-cell cat in the down pipe. Then, at some point maybe mid-2010, Mini switched to a second cat with smaller resonator, and kept that set up moving forward. Later N18 JCWs had the same down pipe and exhaust as S models, with the exception of the rear muffler. Seeing as his car is a later N18 JCW, his car would have shipped with the second cat configuration.
Old Jan 20, 2026 | 06:46 AM
+1 ^ i will look in my basement, But yes the N14 JCW had a two stage down pipe that looked weird.
https://www.northamericanmotoring.co...flow-cats.html
R56 Hi Flow Cats - North American Motoring
Then they went to a normal downpipe.
N14 JCW mid pipe with NO Scrubber Cat. Just a large resonator.
https://www.ecstuning.com/b-genuine-...w/18308608933/
N18 JCW got the resonator and the secondary cat (called a scrubber) https://www.northamericanmotoring.co...-question.html https://www.northamericanmotoring.co...-question.html
https://www.ecstuning.com/b-genuine-...18307637476kt/
Old Jan 21, 2026 | 02:13 PM
cristo's Avatar
cristo
Alliance Member
I stand corrected.
I was going by my (2009)
N14 JCW R55 which doesn’t
have one.
I forgot that they changed it later.
Old Jan 26, 2026 | 08:20 AM
Yep its a weird one with the JCWs and those two stage cats.
big_iz
Mar 14, 2018 06:05 PM
Krazki
Jul 28, 2017 03:34 PM
Piano Man
25
Jun 15, 2015 06:00 AM
Baker555
Mar 26, 2013 11:11 AM
fupac133
Jul 14, 2008 09:04 AM
