R50/53 Shift cable boots (at end of cable on linkage)
Hey all when dropping my transmission and removing the shift cable connections to the linkage the rubber/plastic boots pretty much disintegrated, is it possible to replace these somehow without replacing the entire cable? are they needed for proper function if i just leave them as they are?
@JustinR I believe your looking for this? https://www.bushingfix.com/mini-coop...ushing-repair/
edit: link the wrong one, https://www.bushingfix.com/mini-coop...ushing-repair/
May sound rediculous but - alternatively, you might consider a salvage yard? I've come across some junkers with fairly new or "garage kept" parts on them. I don't build/maintain or replace parts on my Mini with salvage parts - but somethings are unfortunately not sold or not intended to be manufactured = "planned obsolescence".
With consideration to replacing your shift cables - Beware/be advised - depending on when your Mini was built; early pre-facelift ('02-early'04), these cables can be difficult to source (I think there are three variants for the early models). If you have a Mini built after July '04, Your in luck. The facelift cables can be had....
Although, from your picture it appears that you have the early model Mini (?).
Contact@WayMotorWorks Way was able to source the cables for my pre-facelift '04.
Perhaps you might source Home Depot or McMaster Carr to improvise something? (small Vacuum cleaner hose, wire sheeting, a spring + shrink tubing?)...
It's a 2005 but i agree the shift cables look like preface lift ones ive been seeing.
Dependent on model and year. We do have those of those cables in bremmen parts on sale. https://www.ecstuning.com/b-bremmen-...train-shifter/
Run your vin through realoem to double check and watch as some models dependent on year have variants. Condition "A" and Condition "B" and realoem will show a picture of your shifter base to match.
